5 Pages<12345>
nzstato Offline
#41 Posted : Wednesday, 1 December 2010 6:14:47 AM(UTC)
nzstato
Haha yea I didn't have any beer crates around at the time!
Got some of the new welding done in the last day or two. Remember this...
Holes plus a previous repair (just a patch over the rust) that looked horrible, now its like this...
You almost wouldn't know it was there, and who says you cant weld with CO2 (it's just taken me a fair bit of practise).
Got one of the holes up the top done too (doesnt look as pretty as I struggle getting a flap disc near it, it's still solid though)
We're going to get there, after having a bit of a poke around with a screw driver (and seeing the areas with bog on them) I think we've got a bit of work ahead of us...
nzstato Offline
#42 Posted : Monday, 6 December 2010 6:26:01 AM(UTC)
nzstato
Getting into some more rust work, cut another section out of the lower window cavity and found more rust below it...
The new bit was a bitch to weld in, I had to get into the boot and weld above, I also couldnt get my helmet on in the position I was in (had to do the old close your eyes and spot weld, naughty naughty). Needless to say I ended up with a few burns on my chest from dripping weld and a bit of a sunburn from the weld arc. Got it in solid though.
The top skin had alot of 'oil canning' from a previous repair (must have done it too hot) and because I don't have an oxy or a shrinking disc I employed a technique I learnt somewhere else. Take one of your buggered flap discs and mount it back-to-front on the grinder and use that to heat up the metal, then using a wet rag, quench the steel, easy. And we got the new bit in.
Other side with the old repair was a bit of a mess
Going through the motions...
Big Al Offline
#43 Posted : Friday, 10 December 2010 7:28:53 PM(UTC)
Big Al
you're defo doing a top job on her mate. well done.
nice view from your garage too!
nzstato Offline
#44 Posted : Monday, 13 December 2010 5:09:15 AM(UTC)
nzstato
Cheers, we have a pretty mint view from out house (and from outside the garage door) sadly it's only just a rental (buying my own in about 12 months)
Finished the repair around the rear screen (sorry but no photos, they're not that interesting anyway) and thought it would be a good idea to dig into the rear haunches and see what repairs need to be had. Well, I must have digged out about 5 tins of bog! The stuff was half an inch thick in places (example below)
All of the bare metal areas you see had bog of varying thickness covering it
Stupid thing is that half of it didn't even need to be there, 5min of hammer and dolly work would have most of the dents out and whoever did the bog-work didnt follow the contours of the panels but tried to 'straighten' all of the curves out
Being such long panels it would be almost impossible to get them dead straight but I but I can make them a hell of alot better than this, there are a heap of dents across this panel (ex wife with a golf club?) which should come out with a hammer and dolly.
It's about this time that I wished they'd just fill the holes with bog rather than play with the mig..
(some old lead loading in this repair, a rust hole at the edge)
This car would have originally had a chrome strip running down the side, the mig repairs of the holes the chrome fitted into are less than impressive...
This dent in the rear had about an inch of fibreglass filler in it, I'll replace this section, it has began rusting at the bottom.
Soon after I bought this car it needed some rust repair to get a WOF, this is the result
They've brazed small sections in (which is good) but I'm less than impressed with how they line up with the roof section. I'm inclined to leave them there are smooth the area with fibreglass filler rather than mig new sections in since they are right in the area where the roof seam is and there is alot of lead loading around this region (anyone out there recken I should dig out the lead, fix it new and smooth it over in fibreglass?)
So this will definately keep me busy, at least I have a decent amount of time off over xmas/NYs to fix it up.
nzstato Offline
#45 Posted : Wednesday, 15 December 2010 5:44:32 AM(UTC)
nzstato
Surprise surprise I'm onto some more rust repair. But first! I went to a liquidation auction of a local panel shop and picked up some goodies. There wasn't as much there as I hoped but some high dollar stuff did get passed in.
Got some large engineering squares, shot hammers and a blue point speed file. Also included (not shown) was a fire extinguisher, assorted bolts/screws and a clock! all for $30 so I was happy enough. But I digress, back to the repairs
Except for some undercutting of some of the welds this repair has turned out well, it follows the shape in this section pretty close. You can see a heap of holes above, this is where a previous smarty pants has shifted where the badge sits on the pillar, tomorrows job me thinks.
I can really see how this becomes so expensive when you get professionals to do it, it's just so time consuming. Though in saying that there was a mk1 capri sitting in the panel shop where the auction was (it was bare metalled and I assume the customer hadnt picked it up yet) and some of the repair sections on it were VERY average. No wonder they went under.
nzstato Offline
#46 Posted : Tuesday, 21 December 2010 12:24:24 AM(UTC)
nzstato
Right, fixed some previous poor repairs further up the panel (remains of where the edge of where the vinyl roof would have been) now to take a look at this less than impressive wheel arch...
Yummy
Much better
Here's some of the previous crap I've cut out
Backed her out of the shed to remove a bit more bog
this is why it is so crap lapping steel behind the hole is not a repair
Passenger sill isn't too bad, drivers is a bit worse for wear, reckon this is worth saving or best to replace the entire sill?
KeithA Offline
#47 Posted : Tuesday, 21 December 2010 4:57:38 AM(UTC)
KeithA
Your using mig for the panelwork? Gas or gasless? Good work, enjoy your updates.
nzstato Offline
#48 Posted : Tuesday, 21 December 2010 5:43:46 AM(UTC)
nzstato
Yea just a mig, using co2 gas, heard too many bad things about gasless. You can weld panelsteel with co2 it just takes a fair bit of practise. Cheers.
KeithA Offline
#49 Posted : Thursday, 23 December 2010 6:07:07 AM(UTC)
KeithA
Looks like I will have to change my mig over to gas. I've been using gasless since I bought it, but have never tried it on panels. Keep your updates coming, I'm learning from your experiences.
Keith
nzstato Offline
#50 Posted : Friday, 24 December 2010 2:54:49 AM(UTC)
nzstato
Can't say I've tried gasless, just heard its harder to work with and with the smoke it creates
Back to some more work, fixed the poor repair on the rear of the passenger sill.
Now to sort that rear 1/4, after cutting it out the whole thing looked pretty nasty...
Had to rebuild the support & fit an inner section
And I better fix its bum while I'm at it...
Edited by user Friday, 24 December 2010 2:57:14 AM(UTC)  | Reason: Not specified
hztonner Offline
#51 Posted : Friday, 24 December 2010 7:46:11 AM(UTC)
hztonner
HI DUDE YOU DOING GOOD JOB AS I AM DOING THE SAME WITH MY HQ STATO
AS I DO NOT HAVE AS MUCH RUST AS YOURS BUT IT IS THE SAME
AS YOURS AROUND BACK WINDOW WHEN I GET TIME I WILL START PUTTING SOME PIX'S
OF MINE ON HERE SOON AS I CAN WORK OUT HOW TO PUT MY PHOTO'S ON HERE
KEEP IT UP YOU DOING GOOD JOB
CHEERS ALLEN
old fart racing the older i get the faster i was
nzstato Offline
#52 Posted : Thursday, 27 January 2011 5:08:36 AM(UTC)
nzstato
Cheers, be good to see some photos of how you are getting on with yours
Rightoh, I have been doing work, honest.
Fixed up the top of the guard (repairs look like crap in the light
Now need to fix up the lower quarter (the old repair was probably the worse one on the car)
Out with the old...
In with the new... I also had to repair the inner part of the quarter as a fair bit of it had rotted away
Then I decided to have some fun. Off to a stag party in a few weeks (going to take the whole weekend) and decided to make something suitable to bring along.
Take one stuffed HQ disc rotor
Do a bit of welding and add a bit of chain...
Didnt have a heavy ball lying around but this should do nicely. Its not sumthing we're going to let him drag around and the chain is short enough that you have to stoop over to carry it, hehehe
nzstato Offline
#53 Posted : Friday, 28 January 2011 5:54:42 AM(UTC)
nzstato
Pretty productive evening (that makes me happy :) )
Pulled the petrol tank out, still had a bit more fuel in it than I thought so when I undid the straps I had a bit of a challenge on my hands....
Did that so I could weld up all the holes in the boot (any guesses to how many there were?) at some point this car had an LPG system fitted (my guess it was soon after it was bought). But it is long gone, leaving holes where the mounting points and gas lines were. Also a tow bar had been fitted, leaving mounting holes for that.
Still got a bit of original paint back there
It's amazing how quickly you can weld when you're not worried about it being neat...
What's going to be the easiest way to fix this rain gutter? Should I look for a donor and cut a good one off? Anyone had to do this repair before?
Edited by user Friday, 28 January 2011 5:55:50 AM(UTC)  | Reason: Not specified
nzstato Offline
#54 Posted : Tuesday, 1 February 2011 5:42:46 AM(UTC)
nzstato
Onto a bit more, fixed up a small area in the rear of the parcel tray that was annoying me. I have no idea what I have done to my welder but it is running way better than before, zaps through the welds like soft butter and bugger all splatter, any who...
Decided to strip the rear doors as I want to have them hung when I go to line up the rear quarters.
Here's a few good examples of the crap repairs I have been dealing with over the last few months
The bottom area of the inner frame is pretty poor too, poor repairs and they went to the hassle of using filler on the lot to hide the repairs
Heres where they spread some bog over some surface rust, I dont understand some people...
Its a really bad job, they used a curved piece to do the bottom (should have used a flat piece) and really caked on the bog. Now I'm going to have to fix this (cant buy replacements) for two reasons. 1) In UNZUD HQ doors with no rust in them are almost impossible to find and cost their weight in gold (even doors in any reasonable condition are expensive) 2)statesman rear doors are unique to that model so any chance of finding them in reasonable condition quickly is a no show.
Wish me luck
nzstato Offline
#55 Posted : Wednesday, 2 February 2011 6:08:03 AM(UTC)
nzstato
And another quick update as I'm not sure where the next one will be. I really should replace the entire lower skin and the inner with Rare Spare replacements but because they are friggen expensive over here I'm not going to, I'll waxol the lot when I'm done and hopefully it will last a while. Think if I ever find a rust-free set I'll buy them and fit them at a later date.
So, fixing the corners... Lay over a new patch
and cut
Cleaned the frame and loaded it up with deoxidine, primer and sealer, then tacked in the new piece. Then with a hammer and dolly I folded it over.
all done
Haven't finished the other side yet, the corner of the frame needed fixed before I can lay the skin on
nzstato Offline
#56 Posted : Sunday, 20 February 2011 7:24:20 AM(UTC)
nzstato
Rightoh rightoh, I have been doing some work on this, just been away a bit lately which has stalled things somewhat.
Got one of the rear doors finished up, patched the skin and with some minor beating should only need a small bit of filler (skin is straight as an arrow except for the bottom repairs)
Been spending a bit of time stripping the remaining doors, all of which have issues...
Both passenger side doors had bog across the entire skin, thats right, the entire F**kn thing. Rear will be fixable but both of the front doors are really stuffed.
RHR door is fairly well dented, plus has this crummy repair along the bodyline which has warped the skin (fun fun)
Here's the drivers door, what a way to fix the lower skin eh.
The frame has been repaired previously but is pretty well toast
So what am I going to do? Well, in my mind, both of the rear doors are fixable, just a fair bit of hammer and dolly work is needed. Front ones are really bad, passenger is dented to buggery with a fair bit of surface rust and drivers is full of holes. 6 months ago I bought a couple of front doors locally because it was a good deal and I thought I could fix them up and sell them off for a profit, well it looks like I'll be needing them myself now. They are more or less rust free (still need some minor repairs) and I've spend a bit of time already trying to get a massive dent out of the drivers door so this looks like to be the most sensible way forward. Stay tuned...
nzstato Offline
#57 Posted : Saturday, 26 February 2011 5:34:29 AM(UTC)
nzstato
This is either an example of me being a tight arse or and example of being 'inventive'. I need to fix up the other frame for one of the rear doors. I could go buy a rare spares part and weld that in but where is the fun in that?
Cut off the lower of one of the front doors
Make a piece for the corner to blend it in. This is my first real attempt to make a complex shape (even though it's not that complex, ya gotta start some where), reasonably pleased but probably should have given it a bit more of a planish.
Matching it up...
And welded in.... just need to dress up the skin
playwme Offline
#58 Posted : Tuesday, 1 March 2011 7:19:54 AM(UTC)
playwme
Holy crap! You're going to have to change the thread title to "A young fullas nightmare" soon. You've persisted way past where a lesser man would have given up and sold it off as parts though. Good on ya.
This threads also making the missus Valiant look not so bad as well.
nzstato Offline
#59 Posted : Sunday, 13 March 2011 12:26:53 AM(UTC)
nzstato
Yea well us Kiwis have always been known to be tougher than the rest... haha
I now have 4 doors that are made up of more metal that rust, fixed the rear ones that were on it and the ones I had laying around also needed a wee bit of a tickle up before they were ready.
This was a prick to fix, luckily one of the doors I'm scrapping didnt have any rust in this area so I was able to weld an original piece in .
Starting to strip the guards and we find some more appearances of Mr Bog
I knew this area was going to be bad (hmmm I wonder what that area of the nose cone looks like?). The guy I bought it from said it was one of the few areas he attempted to repair when he got it (on behalf of "a mate with a welder"). I'm not going to use this guard at the moment (I will fix it some time in the future), but use one of the ones I have lying around
Sadly they also need a bit of work
But that is no problem...
Had to make up three separate pieces to fix where the rust was, sure I could have bought a Rare Spares patch but where is the fun in that?
In the process of making up one for the other side...
Holdenute Offline
#60 Posted : Monday, 14 March 2011 7:02:04 PM(UTC)
Holdenute
May I be so bold as to suggest that while you've got them in this state, you fix the cause of the rust in this section. That stupid little pocket that catches all the leaves, mud and crap. Maybe box it somehow?
Love your work by the way.
Never late in a V8
5 Pages<12345>
This page was generated in 0.110 seconds.
