nzstato Offline
#1 Posted : Saturday, 19 September 2009 2:42:55 AM(UTC)
nzstato
Hey, Ive got a NZ built HQ stato with the following ID.
8S69TCZ771670
My problem is that I only have 2 of the 3 tags that came with it (by the looks of it was lost years before me during a repaint). Is it possible to get the 3rd tag redone with the correct trim eng info based on the build number above? Not sure if the NZ ones were stamped differently, the only other tag lists options with the code 411 on it (not sure what that means). Also of interest is the 308 in it, stamped 308H30661 date K210 (the original engine was listed as 11QT507028). Any possibility to find out where that engine came from?
Any information on these codes would be much appreciated.
Grue Pugg Offline
#2 Posted : Saturday, 19 September 2009 3:08:15 AM(UTC)
Grue Pugg
308H is HT/G, K210 is 21st oct 1970 so its a HG engine
#3 Posted : Saturday, 19 September 2009 5:18:50 AM(UTC)
You will find that NZ assembled cars ony have two tags. (VIN and body id plate, no compliance plate)
Warren
This page was generated in 0.130 seconds.
