adam PERTH Offline
#1 Posted : Thursday, 24 September 2009 1:02:59 AM(UTC)
adam PERTH
i have one, 3.08 LSD, disk brake rear to suit HQ-WB ute van.
$600 and i will pull it out of the car it is under
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
AdsRuss Offline
#2 Posted : Thursday, 24 September 2009 8:43:28 PM(UTC)
AdsRuss
I would look at taking it off your hands if HGGTS doesnt want it
AdsRuss Offline
#3 Posted : Tuesday, 29 September 2009 10:42:50 PM(UTC)
AdsRuss
How good is it Adam?
Does it need recon or should it be good to go?
adam PERTH Offline
#4 Posted : Wednesday, 30 September 2009 2:04:38 AM(UTC)
adam PERTH
all good.
going for shortened 12 bolt behind chev.
WANTED:
AdsRuss Offline
#5 Posted : Wednesday, 30 September 2009 8:24:34 PM(UTC)
AdsRuss
Sweet. Just gotta get some cash together for you I will be in contact soon. The diff I have is standard with drums on HJ ute. Do you know if I can use same Master cylinder or would I need a new one?
adam PERTH Offline
#6 Posted : Friday, 2 October 2009 3:44:36 AM(UTC)
adam PERTH
You need to use a disk brake rear master cylinder, or you can buy an in line spring pressure reducing valve that goes on the outlet side for the rear brakes.
any good brake shop should help.
WANTED:
AdsRuss Offline
#7 Posted : Friday, 2 October 2009 8:38:23 PM(UTC)
AdsRuss
I should be able to afford it next week. Does tht work with you?
Guest (5)
