Rhys Offline
#1 Posted : Monday, 21 September 2009 1:37:48 AM(UTC)
Rhys
Can any of the experts recommend the best fluid to use? I know that Dexron III is the standard for these autos, but I have used ATF4000 in the past which worked fine.
Also I have seen suction pumps that go down the dipstick/filler hole that can get most of the old fluid out, has anyone had any experience with these?
Thanks guys
Rhys
#2 Posted : Monday, 21 September 2009 1:40:49 AM(UTC)
im not a expert but ive always been told dextron 3 is the best stuff to use
#3 Posted : Monday, 21 September 2009 3:35:50 AM(UTC)
I changed my Cross8 from DexronIII to (I think its called) Valvoline Maxlife, Synthetic. Supposed to make the transmission run cooler when towing.
Sandman Offline
#4 Posted : Monday, 21 September 2009 6:22:46 AM(UTC)
Sandman
I use Castrol Tyoe F in my TH400 and the powerglide in the race car.
I costs the same as Dextron but has a different co-efficient of friction and so makes the shifts firmer. If you just want soft shifts then Dextron 2 or 3 is OK.
Tranzmax Z is a synthetic that is supposed to be very good, but its more expensive.
Rhys Offline
#5 Posted : Wednesday, 23 September 2009 9:31:39 AM(UTC)
Rhys
Thanks for the replies guys. Might just stick to the old Dexron III as suggested as its not a race car and not going to be doing much towing. That should keep her going!
