ozjason Offline
#1 Posted : Monday, 19 September 2005 11:13:20 PM(UTC)
ozjason
Hi all,
I am still playing around with putting this alarm in the Torana, and I started thinking about the power source. Every time I've added another electrical "toy" to the car, (and other cars), I've simply cut into an existing wire near the fuse box, and made sure it's heavy enough to take the extra current.
(Exception has been a Land Cruiser - it had a really cool power supply box under the bonnet with spare terminals.)
However, there comes a point (particularly when working with older cars), when you don't want to stress the original wiring.
Now, in the case of an alarm, running a fresh wire back from the battery or starter motor would be a very obvious wire to cut for a determined thief, so I won't be doing this for the alarm...
But for other things (stereo, central locking, cruise control, spotties, air-horn, etc), what have other people done in regard to this? After market fuse boxes? Home-made arrangement hidden somewhere? Blatantly run a new heavy wire back from the battery to the cabin?
Particularly along the lines of when I rebuild the car, I'd like to do it right the first time, and have neat wiring and a common power location. What have others done?
Appreciate any comments...
Jason.
ChrisHQUTE Offline
#2 Posted : Monday, 19 September 2005 11:30:35 PM(UTC)
ChrisHQUTE
G,day mate just an idea I did with my old ute, I cut into the main power feed into the standard fuse box and wired up an aftermarket fuse box than ran all my extra's off that.
The one I put in had 7 blade fuses in it and a clear cover over the lot, it lo
If a man say's something in the woods and there is no women around, is he still wrong?
Mr Void Offline
#3 Posted : Monday, 19 September 2005 11:48:22 PM(UTC)
Mr Void
I would probably look at running another heavy guage wire (similar to what ChrisHQUTE was saying) but run it from the +ve terminal of the starter motor or alternator. That way it won't be so obvious - run it up behind the dash into a 2nd fuse box and off
___________________
ozjason Offline
#4 Posted : Tuesday, 20 September 2005 1:14:31 AM(UTC)
ozjason
Both excellent suggestions - thanks guys. :-)
Jason.
#5 Posted : Tuesday, 20 September 2005 9:17:01 AM(UTC)
I got the brass junction block off a demolished house fuse box it has a series of screws in it. I bolted it to the fender near the battery and ran a heavy cable to it from the battery, then connect the extras to that, fusing them as needed, not as neat as
#6 Posted : Tuesday, 20 September 2005 9:54:44 AM(UTC)
Hi John,
How did you isolate the brass block from the car body so it wouldn't just short out?
Cheers...Dave
#7 Posted : Tuesday, 20 September 2005 10:40:47 AM(UTC)
Hi Dave
They have a heavy plastic base insulator.
There is also a plastic cover with them if you want to get fancy.
When do you go back? (don't mean that in a want-to-get rid-of-you-way)
#8 Posted : Tuesday, 20 September 2005 10:52:19 AM(UTC)
Off to Alice and Adelaide tomorrow, back to Melbourne on Thursday and off to Tassie for the weekend on Friday night.
Tonight (in Perth) and Thursday night (in Melbourne) are the only two nights I get to stay somewhere that I have stayed before all week
#9 Posted : Tuesday, 20 September 2005 10:54:31 AM(UTC)
Forgot to reply to the answer to my question...
Ah, yes, I have seen them (and used one in my boat as an Earth Block)...they are excellent for distributing power or earths.
Cheers...Dave
bluHJ Offline
#10 Posted : Thursday, 22 September 2005 5:59:37 AM(UTC)
bluHJ
ozjason
I got sick and tired of flameouts in the wiring of my J. This was due to some corrosion in the original fuse box with the glass fuses. I managed to get hold of a fusebox from a later model Ford laser with the blade fuses. I cut this to si
#11 Posted : Friday, 23 September 2005 9:33:58 AM(UTC)
Now, that's a good idea to replace the old fuses with blade ones...
How was the holiday bluhj? Get the cobwebs out?
Cheers...Dave
ozjason Offline
#12 Posted : Friday, 23 September 2005 6:35:28 PM(UTC)
ozjason
Yep, great idea, and I especially like the idea of a ford laser getting around missing a fuse box... :-)
I am currently running all these suggestions through my head, and will probably come up with a combination of them all in the final product!
Ch
bluHJ Offline
#13 Posted : Friday, 23 September 2005 11:12:26 PM(UTC)
bluHJ
ozjason
The laser was already dead so it won't miss the fuse box. I haven't had an electrical problem since it did the conversion and it's only going to get harder to get the glass fuses.
Dave,
Have sent you an e-mail.
I can send you both a
Edited by user Friday, 23 September 2005 11:15:33 PM(UTC)  | Reason: Not specified
ozjason Offline
#14 Posted : Saturday, 24 September 2005 5:57:24 PM(UTC)
ozjason
Actually, I'd love a photo to see exactly how you did it, although your description was very good. :-)
Thanks... email is ozjason and it's at yahoo.com
Jason.
bluHJ Offline
#15 Posted : Sunday, 25 September 2005 12:38:46 AM(UTC)
bluHJ
Jason
Sending them now. They should be in your inbox by the time you read thid
Andrew
#16 Posted : Monday, 26 September 2005 11:04:34 PM(UTC)
Andrew,
Will reply to your E-mail tonight (been cruising Tassie with Taz2 all weekend...it was EXCELLENT!).
Would love a photo of the conversion too.
Cheers...Dave
bluHJ Offline
#17 Posted : Tuesday, 27 September 2005 5:25:17 AM(UTC)
bluHJ
You got it Dave. They're in your inbox.
Andrew
#18 Posted : Tuesday, 27 September 2005 5:54:43 AM(UTC)
Yep, got it mate. Thanks, it looks like a useful conversion.
I'm now not sure whether to do that to the Qute or use the VL Relay and Fuse box under the bonnet....
Cheers...Dave
jabba Offline
#19 Posted : Tuesday, 27 September 2005 4:08:03 PM(UTC)
jabba
Also, Painless Wiring do aftermarket fuse / relay boxes and switch panels (as well as full wiring kits.
I have seen them for sale at Summit racing (US parts site), but Castlemaine Auto Electrics also stock painless kits, so may be able to supply relay
Guest (21)
This page was generated in 0.200 seconds.
