#1 Posted : Tuesday, 20 September 2005 10:28:10 PM(UTC)
Ok the story is i am putting a 253 in my HZ ute tow car and i want change the camshaft to make it tow better. It will be duel fuel, but mostly running on LPG because im a tight arse and petrols too expensive... wahhh
What i want is bulk torque as low as possible because i also want to fit a 2.6 ratio disc brake diff ( if i can make it fit).
I have looked around on the net and found the following:
300AT at tighe cams (tighecams.com.au)
5613 at crow cams (www.crowcams.com.au)
H254 at crane cams (www.cranecams.com.au)
see the respective websites for specs.
Can anyone recommend a cam or give some feedback on these companies?
This page was generated in 0.099 seconds.
