kanks Offline
#1 Posted : Monday, 5 October 2009 6:48:46 PM(UTC)
kanks
hi doing a 304 t700 conversion has anyone done one of these do i need to get the sleg hammer out for clearances etc thanks in advance
HK1837 Online
#2 Posted : Monday, 5 October 2009 7:59:43 PM(UTC)
Floor will need mods, from memory you have to hack into the crossmember at the rear of the box, which done properly needs an Emgineers Certificate. Youll need this for the 304 so you might as well consult one first so its done right.
AGRO Offline
#3 Posted : Tuesday, 13 October 2009 7:53:40 AM(UTC)
AGRO
When i did mine years ago i got a gearbox support from CRS. It used the original holes in the subframe and i think it came with the gearbox support rubber as well.
