GMH1975 Offline
#1 Posted : Friday, 23 September 2005 5:25:15 AM(UTC)
GMH1975
Hi i have a HX sedan fitted with an EFI 308 and day dream about fitting either 2 turbos or 2 of those small jap supercharges such as the ones fitted to 6 cylinder toyotas.
The engine has only done 1000ks and is fairly stock other than it has a HSV computer running it.
Would the jap superchargers give any decent power increase on a 308 and what kind of work would need to be done to set these kinds of systems up?
Would i have to pull the heads off to go the turbo route to lower comp etc?What size turbos would be good to use in this kind of setup?
I dont want to go to a turbo place since im only toying with the idea at the moment and i know JACK about turbo systems and dont want to look like a total dick ;-)
Not the BLOODY Kingswood
#2 Posted : Friday, 23 September 2005 5:52:31 AM(UTC)
Definatley the twin turbo route As long as you dont
go silly with boost pressures and have some basic
fabricating skills you can have a lot of fun
Just not to sure how the factory comp would
handle the boost? Somebody else might be able to shed
som
GMH1975 Offline
#3 Posted : Friday, 23 September 2005 6:07:27 AM(UTC)
GMH1975
All i know about the engine is what is stated on the recipt that the PRICK who built it gave me and that dosnt really state much.
Its pretty much stock with a mild cam and HSV chip .
