#1 Posted : Friday, 23 September 2005 9:11:07 AM(UTC)
i have an HZ triple gauge (oil and temp gauge where the temp gauge normally sits) ... is it simply a matter of installing the gauge, fitting an oil pressure sender unit in place of the switch and thats it? ... fingers crossed it is ....
#2 Posted : Friday, 23 September 2005 10:26:48 AM(UTC)
Pretty much Frank. You may have to extend the current oil pressure light wire to reach the gauge, but the rest should swap straight over.
Cheers...Dave
