#1 Posted : Saturday, 24 September 2005 6:45:54 AM(UTC)
i have a hz sedan with a gts dash recently ive cahnged the oil, now ive noticed that the oil pressure reading on the gts guage are different, its lower. why is this so?? ive used the same oil that ive used before??
#2 Posted : Tuesday, 27 September 2005 2:41:39 AM(UTC)
I too have a HZ with a std red 253, I have a Speco oil preasure gauge fitted and I get 50psi @ 2300rpm, after a while gets down to 40psi.At idle it drops to 10-15psi on a hot day. Make sure the idle is set right as if its too low then the preasure will dr
#3 Posted : Thursday, 29 September 2005 6:21:52 AM(UTC)
did you change the filter too?
dont the pumps pump into the filter?
if so, and your filter was a bit blocked, then the pressure drop would be a good thing (more flow)
remember, flow is better than pressure.
DO NOT WRITE BELOW THIS LINE
#4 Posted : Thursday, 6 October 2005 9:51:43 AM(UTC)
High volume oil pumps are the best way to keep the pressure up. They look the same as originals but they are cast steel and protect your cam and lifters better. JP Engineering make them in Adelaide I think. Wayne
#5 Posted : Thursday, 6 October 2005 9:58:25 AM(UTC)
It is perfectly normal for the pressure to be around 4-7 psi at idle and run at around 28-32 psi .
High pressure pumps are not necessary and in fact undesirable in a street engine as they can wash the bearing material out. I would think 50 psi is either
#6 Posted : Thursday, 6 October 2005 9:59:19 AM(UTC)
Also if you changed the gauge did you fit the right sender?
#7 Posted : Thursday, 6 October 2005 11:38:20 AM(UTC)
How does it wash the bearing material out, the pressures are normal just a bit more constant throughout the rev ranges. High volume not high pressure. Anything over the relief valve will be by-passed anyway. Oh well its served me well for the past 10 year
#8 Posted : Friday, 7 October 2005 9:03:27 AM(UTC)
Read Cranes site. The pressure washes the surface tinning off the bearing and it breaks up. I am only going on the pressure recommendations in the Holden shop manuals.
