Taz2 Offline
#1 Posted : Tuesday, 27 September 2005 5:12:03 PM(UTC)
Taz2
The speedo in my Level 3 VN dash has gone dead!
I've swapped a couple of speed sensors over, but the problem still exists.
I've also swapped a couple of speedos (not the entire dash cluster), but no change.
Anyone have an idea what else I need to check?
Speedo was working fine a few days ago, and the rest of the dash is working as it should.
In thrust we trust
#2 Posted : Tuesday, 27 September 2005 6:37:56 PM(UTC)
Is it auto or manual? Checked the fuse (12) and all your plugs? the main Speedo, rev and neutral switches run down past the centre consol but then through a another plug...around where the dash/centre consol meet. In that plug is also the cig lighter, if
Taz2 Offline
#3 Posted : Wednesday, 28 September 2005 4:49:49 AM(UTC)
Taz2
Err, umm, I checked fuse 10.....I'll try fuse 12 :-)
The car is auto.
Rev counter & neutral works fine, so I guess it's not a wiring problem....at least not in that area.
I don't use the cig lighter so that rules that one out, but I'll check the earth
In thrust we trust
#4 Posted : Thursday, 29 September 2005 6:03:10 AM(UTC)
the flexible circuit card, that raps around the back of the dash cluster can break.
i have found a few speedo's and tacho's with this problem.
basically the signal runs to the plugs in your main dash, attatch to the dash cluster, they then run to the ga
Taz2 Offline
#5 Posted : Tuesday, 11 October 2005 3:49:39 AM(UTC)
Taz2
Well fatboyvncalaisv8 wins the prize/cake...ummm nothing really
Discovered today that the flexible circuit card had a crack in it right where the speedo attaches.
Changed the card and everything now works fine.
Good to have some indication of what spee
In thrust we trust
#6 Posted : Wednesday, 12 October 2005 4:56:32 AM(UTC)
mmmm.......cake!
its seems quite common.
like the fuel lines near the filler perishing.
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
#7 Posted : Saturday, 15 October 2005 12:49:21 AM(UTC)
Good to hear you got the speedo going Taz2.
I got home at 7 pm last night after 1287 K's yesterday including 2 hours visiting a mate in Kalgoorlie....Looooong day!
Bathurst was veeeeerrrrryyyy cold! At 9:30 they announced that it was 4.8 degrees, b
