RdS Offline
#1 Posted : Friday, 30 October 2009 6:22:41 AM(UTC)
RdS
hopefully a fairly simple question;
i have a 253 with a new reproduction 4barell manifold on it (not sure of brand - got it from the mechanic).
i have a quadrajet to go on, but havent got bolts/studs long enough to hold it down! (on the quad atleast 2 of the bolts/studs go all the way through the carb).
anyone know the specs of the bolt or stud/nut i need for it? UNC 5/16 yeah? also how long, and where would i get something like that? asked autobarn/repco/rare-spares last weekend, but no luck getting studs long enough.
help would be appreciated. :)
4/76 HJ monaroGTS
4/76 HJ monaroGTS
Keeo Offline
#2 Posted : Friday, 30 October 2009 6:40:50 AM(UTC)
Keeo
get some allthread (a long length of theaded bar)from a nut and bolt shop,and cut it to length file the ends neat.Take a sample thread with you .
#3 Posted : Friday, 30 October 2009 8:42:58 AM(UTC)
AS ABOVE ,also good for holding on the chrome air filters ,just take the thread you need .dead easy.
Jim in Adelaide
bundybluedog Offline
#4 Posted : Friday, 30 October 2009 9:42:09 AM(UTC)
bundybluedog
booker rod is what you want, never heard it called All thread before, Might be a southern thing? Get anything above 8.8 grade
#5 Posted : Saturday, 31 October 2009 3:09:49 AM(UTC)
ive never heard it called booker rod before, only all thread?
80569K Offline
#6 Posted : Saturday, 31 October 2009 4:22:28 AM(UTC)
80569K
Ive never heard it called all thread or booker rod either, only ever known it as "threaded stock".
Keeo Offline
#7 Posted : Saturday, 31 October 2009 5:58:38 AM(UTC)
Keeo
Man this forums unreal .
#8 Posted : Saturday, 31 October 2009 8:07:58 AM(UTC)
bundybluedog
Have heard of threaded stock, when i worked as a fitter and turner its what most called it and at college when i apprenticed it was always called booker rod. All 3 work if the shop keeper isnt sure you can throw all three at him.
peter_flane Offline
#9 Posted : Saturday, 31 October 2009 9:47:42 AM(UTC)
peter_flane
Threaded rod would be a simple universal name that should be understandable by description. Rod that is threaded.
Allthread, Booker rod, threaded stock, cyclone rod. They can be well known in certain industries and trades.
#10 Posted : Saturday, 31 October 2009 5:08:24 PM(UTC)
Id never heard of Allthread, although its name is very descriptive & leads you to assume its threaded rod.
Ive always had it called "Brooker Rod" wherever Ive worked, so seeing "booker" got me a little confused.
I did a little google search & found this:
http://www.hobson.com.au/page/history.html
"Threadrolling was a relatively new technology which held great potential. Brooker, of the coined phrase "BROOKER-ROD", started producing fully threaded rod (ALL THREAD) just after the war."
I guess its just the Australian way of knocking out a few syllables or letters wherever possible to make things simpler!
#11 Posted : Saturday, 31 October 2009 7:10:42 PM(UTC)
bundybluedog
well now i feel like a tool hahaha i have never wrote it down before or read it of paper and to me it just sounded like booker rod. noone has ever corected me in 11 years in the indurtry.
I had an arguement with a guy once on a job in W.A i had to order a Viton O-ring for some hydraulic part, he said it was Vitron not viton he ended up being wrong and larfed about it cause he had been in the industry for over 30 years and one of the best hydrualic fitters i had ever met and noone had corrected before him either.
RdS Offline
#12 Posted : Tuesday, 3 November 2009 1:06:05 AM(UTC)
RdS
thanks for the help.
didnt end up going for some threaded rod, as Bursons had 3+1/4" 5/16 UNC->UNF stud and nut sets. should do the trick. :)
4/76 HJ monaroGTS
4/76 HJ monaroGTS
