#1 Posted : Friday, 30 September 2005 10:32:31 PM(UTC)
Genuine Ford 5/8" steel T piece in the heater circuit rusts out in a few years even using a good quality coolant. Kilkenny manufacture a 5/8" brass T piece BUT (according to my micrometer) the vertical section of the T piece is undersized thereby allowing fluid to bypass (Kilkenny should improve their tooling) and there is not sufficient space on the spout to attach 2 worm clips. What is the smart fix? Thanking you in advance for your replies.
Paul351xb Offline
#2 Posted : Saturday, 1 October 2005 1:34:38 PM(UTC)
Paul351xb
What I would be doing is taking the original Ford piece to the nearest fitter and turner and getting them to knock me up a new one out of either brass or stainless. Fortunately my brother is a fitter and turner so if I get into a bind at least I can call
#3 Posted : Tuesday, 4 October 2005 9:34:43 PM(UTC)
Hi Paul,
Re your post 1/10/05 if your brother intends to turn out a 5/8" brass or stainless T piece for you he may care to make another am in Brisbane my work mob.is 042245 1114 personal mob. 040376 99 55 and I will ring you back. Thanks in advance
Paul351xb Offline
#4 Posted : Saturday, 8 October 2005 11:55:45 PM(UTC)
Paul351xb
Jack,
I have no need for a T piece but I'll give my brother a call and see if he can knock you one up and how much. He has just started work with a new firm so I am not too sure if they allow him to "play" on the machines like with his old job. If he c
#5 Posted : Saturday, 22 October 2005 7:49:05 AM(UTC)
Hi Paul,
Thank you for offer of assistance. I was so browned off I contacted Kilkenny and they replaced it with a T piece that has been tooled accurately (no more bypass of fluid). Ford also need to improve their quality control because when I replaced t
This page was generated in 0.100 seconds.
