Vintage Caravans Offline
#1 Posted : Monday, 16 November 2009 12:07:20 AM(UTC)
Vintage Caravans
Hi Guys, this may have been asked before but I cant find it?
I have a V8 VN diff I am narrowing to fit an EK but using short axles on both sides, HOWEVER
I want to run Chev stud pattern. can the VN axles be re-drilled safely or should I just get new axles made up for the application?
IF new axles are the go, should I get them made in billet? car is running SBC and T700
Matt
79 F100 XLT 351, 62 EK Wagon-327, 62 EK Ute-327, 62 EK Van-307 62 EK Sedan-202
Spot the odd one out??!!
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
peter_flane Offline
#2 Posted : Monday, 16 November 2009 8:18:40 AM(UTC)
peter_flane
It is illegal to redrill axles. Billet is your best choice, and with the SBC you will have confidence in the axles as they were a weak point in the BW diff.
vintageholden Offline
#3 Posted : Monday, 16 November 2009 8:50:14 AM(UTC)
vintageholden
arnt chev close to commodore pcd???
peter_flane Offline
#4 Posted : Monday, 16 November 2009 8:58:24 AM(UTC)
peter_flane
Yes they are close, but not the same. It is not a good idea to shove a Chev 120.65mm PCD on a Commodore 120mm PCD.
HQforme Offline
#5 Posted : Tuesday, 17 November 2009 4:02:15 AM(UTC)
HQforme
That PCD question is probably the most asked question in wheel-related history! Haha. Many people put Chev pattern wheels on commodore PCD, or vice versa. We call these people, idiots, or accidents waiting to happen.
And now someone will come along and say "ive had that setup for years with no problem".
Wheelnuts/studs take the load, they wont be happy if theyre under stress just from being done up.
"Silly modern cars"
#6 Posted : Tuesday, 17 November 2009 5:11:22 AM(UTC)
vintageholden
like you said my mate has had them on for years....
maybee .65 isnt that much...
Utility8 Offline
#7 Posted : Tuesday, 17 November 2009 5:19:29 AM(UTC)
Utility8
HQforme, youre right, asked many times, and the answer is always the same.
Cutting corners, doing it cheap, this should work, been doing it for years, a mate reckons, cant you just do this?, whats wrong with doing it this way?, thats too hard/costly.
Do things correctly for the safest & best result. Its not rocket science.
Utility8
utility8
peter_flane Offline
#8 Posted : Tuesday, 17 November 2009 5:57:40 AM(UTC)
peter_flane
Cars have been getting bogged up with an inch thickness of body filler for years and no problems! Or do they? Would you accept that on your car? How many cracked and rusted bogged panels have you seen? Lasts a while, sometimes many years, but not always.
#9 Posted : Wednesday, 18 November 2009 5:03:16 AM(UTC)
Vintage Caravans
Thanks for the input guys, I want this one done once and done right, so Billet Customs it is
Matt
