#1 Posted : Wednesday, 3 December 2003 8:07:33 AM(UTC)
I want to drop my xe v8 with kings "super low" springs,will i have to replace the gas shocks i have now with shortened shocks or can i do something to raise the top shock mounting bracket?,any help will be greatly appreciated. Larry David
#2 Posted : Thursday, 1 January 2004 8:57:02 AM(UTC)
personally, id buy the new shocks to go with the new suspension system, saves a bit of the money in the long run, and you will know that the shocks that you got will be up to the task.
an extra 200 bucks per end of the car maybe?
78XC Offline
#3 Posted : Thursday, 15 May 2008 5:18:44 AM(UTC)
78XC
whatever you do make sure your not on your bump stops under load as I lowered my XE and it just locked up it took forever to stop so if your close you might have to either cut them or do something. I also agree get short travel shocks you've gone this far
#4 Posted : Thursday, 15 May 2008 5:24:49 AM(UTC)
Yeah agreed, new shocks. After all you will be removing them to replace the springs anyway. I just hope the rest of your front end is up to the task, it is not always about looks.
Paul351xb Offline
#5 Posted : Thursday, 15 May 2008 7:58:58 AM(UTC)
Paul351xb
Ummm, guys this post goes back to 2003. If the problem hasn't been solved by now then this person must have the same amount of patience and laziness as, well..........me.
This page was generated in 0.117 seconds.
