HQforme Offline
#1 Posted : Thursday, 19 November 2009 3:32:50 AM(UTC)
HQforme
Finally im getting on top of this EFN 202. Pistons used were RA3302, which have 7.2cc dish and sit 0.035 down the bore. It's a 40thou over 202 (3.665) and the new head i have (YT modded 161) has a chamber volume of 50.6cc according to the guy who cc'd it for me. With gasket, this would give me 8.9/1 compression acording to this: http://www.csgnetwork.com/compcalc.html
That calculator, by the way, came within .1 of the Dyno2000 software used by my tuner.
So i made 102rwhp at 5000rpm with the same motor, but my open chamber head (shaved 0.030) which i ported and has bigger valves, but not as big as the YT. And it was running rich. Not too bad?
Now, how do we get comp up considering ACL has run out of 40thou flat-tops (more on order) and i'd prefer not to strip the motor for new pistons anyway.
How can i tell how much i could take off the head safely? Would this acheive what i desire, and that is comp around 9.8/1 or 10/1 , which is what the 2cc dish or flat top ACL piston would give me.
Thoughts are appreciated.
"Silly modern cars"
HQforme Offline
#2 Posted : Thursday, 19 November 2009 5:07:42 AM(UTC)
HQforme
Oh, i need to get 5cc out of the chambers to achieve desired compression ratio, if thats possible. Looking at the head, its been lightly shaved, but theres still a good bit between the level of the head and the little divots in the casting that signify wear level, i think? So im thinking go 40thou and then measure?
"Silly modern cars"
#3 Posted : Thursday, 19 November 2009 9:28:41 AM(UTC)
I had a VK 202 head took 40 thou off, which I calculated gave around 10:1, but my maths is not that good.
If you go over 40 thou I was advised by Crane Cams the rocker angles will be excessive (stock EFI cam) so not advisable unless you want to go into modifications there.
if you take material out of the head chambers you will actually be lowering compression, not exactly what you want I think.
Davesmonaro68 Offline
#4 Posted : Thursday, 19 November 2009 8:17:12 PM(UTC)
Davesmonaro68
Get the block decked and get rid of that 35 thou and which will fix the squish area up and whatch her boogie.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
HQforme Offline
#5 Posted : Thursday, 19 November 2009 10:02:15 PM(UTC)
HQforme
Cheers. I know decking would do it, but trying to avoid pulling the motor down, its a daily car at the moment.
John, your VK would have had non-adjustable rocker gear. This 161 head has adjustable so i think it gives me more leeway before running into valvetrain problems? And you may well have got 10/1 with a shave if you went up from stock compression. The pistons in mine dropped comp from 9.4/1 (standard 202) to 8.9/1 and thats what im trying to recover.
Edited by user Thursday, 19 November 2009 10:03:15 PM(UTC)  | Reason: Not specified
"Silly modern cars"
#6 Posted : Friday, 20 November 2009 10:10:52 AM(UTC)
the adjustment wont help you with the angle of the rockers it will only alter the valve to tappet clearance.
but once you sort out what you need there are different angled bits available.
Taking off 100 thou wont hurt. I know guys have taken 160 thou off and it still runs and with the standard rockers but maybe not so reliable.
HQforme Offline
#7 Posted : Saturday, 21 November 2009 12:39:27 AM(UTC)
HQforme
Ah of course, itll affect the angle and result in the contact point moving rearwards a tiny bit. With the 40thou, plus the small amount it was shaved originally, hopefully we wont have any problems. Worst case, i had to run lash caps on my current head until i bought adjustable shaft mount rockers. It was fine with the caps.
"Silly modern cars"
