#1 Posted : Monday, 10 October 2005 4:06:15 AM(UTC)
hey, just gonna start puttin a GTS dash into my kingswood ute, was wondering if the wiring looms are the same or whether u have to modify the wiring to suit. is it just a matter of rewiring the gauges using the existing wiring and then puttin it all back together or will i come across some problems??? also is there anywhere u can buy replacement gauges as my voltmeter is stuffed and as the car is pretty schmick i wanna keep it that way not puttin it faulty/dodgy stuff. thanks
#2 Posted : Wednesday, 12 October 2005 12:41:34 AM(UTC)
dash plugs straight in, if your puttin hz gts dash into hz no wiring mods, if you were putting hj x gts dash into hz then you would have to run an extra wire to tacho, you can have the gauges repaired, use the yellow pages, which state r u, ps if you kn
