Biga064 Offline
#1 Posted : Sunday, 29 November 2009 6:42:04 AM(UTC)
Biga064
I have now had two aluminium trolley jacks purchased from autobarn only over a 5-6 month period fail to stay up while being used. They pump up but then slowly go down after a minute . Still have fluid in them and are not leaking . Lubricated as per instructions. Any one else out there had the same problem ?
bundybluedog Offline
#2 Posted : Sunday, 29 November 2009 7:04:59 PM(UTC)
bundybluedog
check that your down screw is seating properly, they also have a 1 way valve or check valve between the 2 cylinders it may be broken aswell.
