Fastlane
Holden Forums
Holden General Discussion
Autobarn Aluminium trolley jack problems
Groups:: Registered
I have now had two aluminium trolley jacks purchased from autobarn only over a 5-6 month period fail to stay up while being used. They pump up but then slowly go down after a minute . Still have fluid in them and are not leaking . Lubricated as per instructions. Any one else out there had the same problem ?
check that your down screw is seating properly, they also have a 1 way valve or check valve between the 2 cylinders it may be broken aswell.
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Fastlane
Holden Forums
