charlie Offline
#1 Posted : Tuesday, 15 December 2009 7:00:38 AM(UTC)
charlie
I have a 202 on gas and petrol, i run it most of the time on gas, and have it set at around 10 to 12 degrees.
i know how to tune a carb but not the gas, under the air cleaner it reads
1)power
2)idol a screw in the middle
3)rich----lean bolt
whats the best way to tune her, as i seem to be using alot of gas lately, only get about 80 kays per 30 litres, ive checked for leaks with some soapy water while running and found and fixed a small leak.....
#2 Posted : Tuesday, 15 December 2009 9:26:51 AM(UTC)
i dont know about tuning but i do know there is never a small leak with pressurized gas,thats where your economy is.
vintageholden Offline
#3 Posted : Tuesday, 15 December 2009 11:41:15 AM(UTC)
vintageholden
you nead a gas analizer
get a tune about $80
what converter do you have....
OMVL???
charlie Offline
#4 Posted : Tuesday, 15 December 2009 6:35:30 PM(UTC)
charlie
The converter is a b4 .....the leak was at the first solenoid that you see in the engine bay, when i put soapy water there it bubbled ever so slightly..was hard to pick up .
