bundybluedog Offline
#1 Posted : Friday, 1 January 2010 8:44:22 PM(UTC)
bundybluedog
I know its been asked a few times but i cant find the link so ill ask again. Whats involved in changing a 4 cylinder model of the lj lc torana into a 6? i have a very tidy complete LC sedan and would like a 2 door with out the cost of buying an origanal 2 door 6 cylinder.
What should i expect to pay for an old 4 cylinder roller with all the door mechanisms and window winder and glass?
#2 Posted : Friday, 1 January 2010 8:59:28 PM(UTC)
everything from the firwall forward needs to be changed, the 4 cyl fronts are shorter
#3 Posted : Friday, 1 January 2010 10:09:02 PM(UTC)
Rear suspension mounts are different too. Youd be better off getting a 4cyl 2 door and using the quarters and doors on the sedan.
Premier 350 Offline
#4 Posted : Saturday, 2 January 2010 9:28:21 PM(UTC)
Premier 350
Also on the LC-LJ the 4 cyls had from memory a salisbury diff- 4 stud 12" wheels. Also differnt gearboxes. Not sure if the floor pan is the same as the sixes, so gearbox fit might be an issue.
A tarted up Fairmont is NOT a legendary muscle car.
