I know its been asked a few times but i cant find the link so ill ask again. Whats involved in changing a 4 cylinder model of the lj lc torana into a 6? i have a very tidy complete LC sedan and would like a 2 door with out the cost of buying an origanal 2 door 6 cylinder. What should i expect to pay for an old 4 cylinder roller with all the door mechanisms and window winder and glass?
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
everything from the firwall forward needs to be changed, the 4 cyl fronts are shorter
Rear suspension mounts are different too. Youd be better off getting a 4cyl 2 door and using the quarters and doors on the sedan.
Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
Also on the LC-LJ the 4 cyls had from memory a salisbury diff- 4 stud
12" wheels. Also differnt gearboxes. Not sure if the floor pan is the same as the sixes, so gearbox fit might be an issue.
A tarted up Fairmont is NOT a legendary muscle car. |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
