KiwiHQ Offline
#1 Posted : Friday, 21 October 2005 12:47:12 AM(UTC)
KiwiHQ
Hi there guys and gals,
I have what i thought was a buckled wheel as it was wobbling all over the place. Just come from the tyre shop and the wheel is 100% straight.
I had a new wheel bearing fitted at Xmas.
Not knowing much about from the wheel inwards... could it be a bent axle as it only happens on the drivers side?
Would it be easier to buy another complete diff. Question is, how do you test such a thing easily as i dont want to buy another one with the same issue.
Rock n Roll
Rock n Roll
KiwiHQ Offline
#2 Posted : Friday, 21 October 2005 12:48:23 AM(UTC)
KiwiHQ
Should have added, HQ, 253 with 3.08 diff ratio if any of that helps....
Rock n Roll
Rock n Roll
#3 Posted : Friday, 21 October 2005 6:03:52 AM(UTC)
I got my diff recond about 6 weeks ago one of the axcels was r/s cost me a $75 for a new one
#4 Posted : Saturday, 22 October 2005 7:50:31 AM(UTC)
can you get someone to drive behind you and see which wheel it is?
if its only the axle not a real hard job to fix.
#5 Posted : Sunday, 23 October 2005 9:09:05 AM(UTC)
It is almost certainly a bent axle. The wheel would be on a slight angle if the housing was bent but it would not wobble.
There is probably only about three ways to see if a second hand axle is straight. One is to turn it in a lathe and put a dial
#6 Posted : Monday, 24 October 2005 5:53:10 AM(UTC)
convert it to a 9 inch or something.
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
#7 Posted : Monday, 24 October 2005 9:51:22 AM(UTC)
A 9" behind a 253? No way...9" diffs chew up waaay too much HP to use them unless you need the extra strength.
Cheers...Dave
