AMunro327 Offline
#1 Posted : Thursday, 14 January 2010 2:46:26 AM(UTC)
AMunro327
On a V8 HK, there is a spacer between the crossmember and engine mount. There are two size spacers, one for each side.
Does anyone know which is which? i.e. is the longer spacer for the left or right hand side? The Shop Manual doesnt give any detail and the Parts Manual just lists them as two different part numbers.
#2 Posted : Thursday, 14 January 2010 4:42:57 AM(UTC)
The longer or taller one is for the drivers side.
www.monaromuscleparts.com
AMunro327 Offline
#3 Posted : Thursday, 14 January 2010 4:58:56 AM(UTC)
AMunro327
Thanks for that MMP. Do you know why they are different lengths, why get one side of the motor up higher than the other?
Keeo Offline
#4 Posted : Thursday, 14 January 2010 6:23:16 AM(UTC)
Keeo
Its just the way it is (chev into hk) the firewalls really close on left side.--cheers keeo
