RJR Offline
#1 Posted : Tuesday, 25 October 2005 12:39:11 AM(UTC)
RJR
Hi Guys, FJ's, I have bought an FJ that's 90% restored if i want to put different wheels on other than the standard FJ rims has any one have any ideas what type of rim i could use i.e mags on a FJ hub, I'd appreciate any suggestions and have been talk into keeping the original motor which has only 61thou on the clock, should i put a few xtras on that motor also, and also do away with the column shift and fit a 5 speed celica box what are your thoughts, i was talked out of putting a V6 into it and keeping it as original as possable. can y'all thanks
#2 Posted : Thursday, 27 October 2005 6:46:17 AM(UTC)
well about the mags i dont think you can put any nice ones on them unless you wont to change your stud pattern to a HQ or something
zac
only milk and juice comes in 2 litres!!!
#3 Posted : Thursday, 27 October 2005 7:14:15 AM(UTC)
The easiast way to change your stud pattern is to run the original king pin front end with early FE hubs and HD drums, and replace the FJ rear with a HR item. You then have many options of wheel and tyre combo's.
RJR Offline
#4 Posted : Sunday, 30 October 2005 9:03:43 PM(UTC)
RJR
thanks for your replies guys, well since found out from Mag and Turbo that there is one in the Boyd Coddington range called(Smoothie 1)that can be fitted, and in the Performance Wheels Range, so really only 4 to choose from, looking at the Smoothie polish
This page was generated in 0.113 seconds.
