#1 Posted : Monday, 31 October 2005 7:04:42 AM(UTC)
Hello everybody,
Stumbled across this site and thought I would ask a question, which is: My EF Futura seems to stumble and almost stall when I put it into drive, and also when I pull up it seems to stumble a bit but then idles alright after a few seconds, its kinda like a very rough vibrating idle kind of stumble, if that makes sense, everything else seems alright, performance and fuel economy seem normal, and I keep it serviced regularly (most of the time anyway!)any help greatly appreciated!
#2 Posted : Saturday, 15 April 2006 2:26:28 AM(UTC)
Same problem with my wife's.2 differant Ford dealers can't seem to fix it.
#3 Posted : Sunday, 16 April 2006 6:18:24 AM(UTC)
Clean the throttle body around the throttle plate with carby cleaner. Make sure you open the throttle up an get right in there - Use your girlfrinds toothbrush, they work well. It may be that. If you clean it well you will use most of the can. The engine
#4 Posted : Sunday, 16 April 2006 11:04:04 PM(UTC)
This is what the 1st ford dealer did.Thanks anyway
#5 Posted : Monday, 17 April 2006 6:13:42 AM(UTC)
gday - just in case it helps, we had same symptoms with our ef. turned out to be the gearbox torque convertor solenoid. basically the thing wouldn't allow the engine to rev down to idle as you were slowing or came to a stop, felt like it was stuck in high
#6 Posted : Monday, 17 April 2006 9:02:46 AM(UTC)
is it on gas ?. disconect battery to reset computer. if this does not work replace IAC valve.luke motor mechanic.
#7 Posted : Monday, 17 April 2006 9:03:34 AM(UTC)
P.S could be a power stearing switch.
