Keeo Offline
#1 Posted : Monday, 1 February 2010 6:04:26 AM(UTC)
Keeo
What is the correct size blinker bulb for a Hktg ?4/32 cp is what the manual says.I know its atwin filament but is it 5W or 6W or something else . cheers --keeo
#2 Posted : Monday, 1 February 2010 5:58:29 PM(UTC)
Hi Keeo.
If you are referring to the rear globes, they are 21 watt (single filament). The front globes are double filament 21/6 watt (modern equivalent is 21/5) & the ones in the dash are 6 watt.
The old 32/4 cp globes are not seen much these days & cp = candle power.
There are only 3 types of people in the world.
1. Those who make things happen.
2. Those who watch things happen.
3. Those who wonder what happened.
80569K Offline
#3 Posted : Monday, 1 February 2010 6:12:02 PM(UTC)
80569K
The c.p. number is to do with the brightness of each filament. To fix the dramas I was having with ancient bulbs I bought a full set of new bulbs, coloured for the rears and clear for the fronts and not a c.p. in sight.
When you install them make sure they are inserted the right way round ie, blinkers & stop bright and parkers & reverse less bright.
Thankyou Dr T cp = candlepower.
Edited by user Tuesday, 2 February 2010 12:25:44 AM(UTC)  | Reason: Not specified
Keeo Offline
#4 Posted : Tuesday, 2 February 2010 4:32:37 AM(UTC)
Keeo
Much appreciated,it was the front sorry but glad you included the rear as their next.ahh candle power of course!--cheers keeo
