#1 Posted : Wednesday, 2 November 2005 1:21:59 AM(UTC)
if you are thinking of a/c your ride , here are some things to consider .
you will need a compressor,compressor mount and
drive kit ,consender ,evaportor unit
(underdash or conceal type ),
r/drier and bracket, pressure switch , electric fan ,and a/c hoses and wiring .
you will need an auto electrical / a/c man to help with a/c hoses ,but the rest can be fitted by an mechical mined person .
any other a/c issues , i will gladly help with .
regards
nigel
http://www.geocities.com/radiatorexpert/
#2 Posted : Tuesday, 22 November 2005 7:54:53 PM(UTC)
I am having problem with AU heater valve operation, heater valve doesn't shut down when turned to off position, all vacuum lines are connected, I have in the back of my mind that there is a simple fix to this with a vaccum switch fault, but can't for life
