You have been a member since:: 17/04/2005(UTC) Posts: 465
Wanting to remove the trim that runs down the waistline of the HJ (door protection strip type thingy) for repaint. Does it unclip, unscrew or is it a chisel off jobbie?
__________________________________________ Keep the shiny side up, and the greasy side down. |
I did my wb statesman took 4 days(painting aswell),pop in clips ,there are different types we all would need photos.
Jim in Adelaide...Hindsight is bad vision! |
Jim in Adelaide.. |
are they the glue on strip?
assuming they are, get a hair dryer and heat them up and they will pull off, if you dont get them hot enought the paint underneath will peel off with the strip, which wouldnt be a huge problem if your re-painting it anyway
