RdS Offline
#1 Posted : Wednesday, 17 February 2010 8:23:10 PM(UTC)
RdS
having a bit of trouble finding the info on the internet...
but how big are the factory HZ RTS front and rear swaybars?
~24mm front, and ~18mm rear?
hard to find out for sure.
as an upgrade to thicker whitline branded bars, would a 27mm would be the go for the front? they do an 18mm and 20mm rear, but theyre catalogue says excl HZ. is this because it already has a similar bar from the factory, or is there some difference in the way it mounts to hq-hx which makes it non-compatible?
cheers..
4/76 HJ monaroGTS
4/76 HJ monaroGTS
RdS Offline
#2 Posted : Wednesday, 17 February 2010 10:09:40 PM(UTC)
RdS
answered my own questions i think. 24mm front, and 16mm rear from factory supposedly.
and whiteline make a seperate HZ rear swaybar. wasnt in the catalogue for whatever reason. 18mm only.
F: BHF7 for the 27mm
R: BHR10 for the 18mm
done.
4/76 HJ monaroGTS
4/76 HJ monaroGTS
states_man Offline
#3 Posted : Wednesday, 17 February 2010 10:23:08 PM(UTC)
states_man
bars are 24mm and 16mm on my HZ caprice (with RTS). HZ diff housing has stabiliser bar mounts welded to it, HQ to HX do not as they have no rear bar. when fitting rear bar to HQ-HX you would need U bolts to go over the diff housing. also the bar bolts to the side of the lower trailing arm on HQ-HX as they dont have mounts for the link pins
Brian
RdS Offline
#4 Posted : Thursday, 18 February 2010 12:30:37 AM(UTC)
RdS
thanks for that. confirms what i had figured.
hopefully this thread should pop up for anyone google-searching for this info in the future. :)
4/76 HJ monaroGTS
4/76 HJ monaroGTS
