#1 Posted : Wednesday, 9 November 2005 5:05:18 AM(UTC)
Hi guys the brakes on my hz s/w are working but they have
no bite if that makes sense. Ive done new rotors rekitted
my pbr callipers put a new master cyl on with new metal king
pads bedded them in over 500ks or so still no bite will lock
fronts at low speed but still no bite at speed any ideas much
appreciated
cheers chris
#2 Posted : Wednesday, 9 November 2005 8:38:26 AM(UTC)
proportioning valve? go down to ya local clutch and brake shop and get a lone of a pressure test kit.(mite cost ya a carton)the kit has 2 gauges which screw into ya bleeder holes,apply the brakes and check the difference between front to rear.their would
trubluhq Offline
#3 Posted : Wednesday, 9 November 2005 4:56:18 PM(UTC)
trubluhq
Could be a bleed issue, liek some air in the lines, or even the metal kings. I was told they are too hard and dont give like the older style pads.
John
#4 Posted : Thursday, 10 November 2005 6:35:44 AM(UTC)
metal kings need high heat range and frequent application to be affective and even then thell wear or even warp your rotors ,if you have bled your brakes correctly ie 2 people build up pressure then release.1 man kit not affective.,then you may have glass
