#1 Posted : Sunday, 13 November 2005 8:00:39 AM(UTC)
Hi Guys,
as some of you may know I'm wrecking a HT ute + I'm trying to remove the doors. I have taken out all 8 hinge bolts on either side + I haven't forced anything yet, BUT! both doors are still holding on as firmly as if the bolts are still in there...is there a trick to getting the buggers off or do i just need more anger? :O
Cheers, Elton.
BTW, Kel if you read this i've removed the front panels and the rails are good on both sides.
Edited by user Sunday, 13 November 2005 8:03:24 AM(UTC)  | Reason: Not specified
#2 Posted : Sunday, 13 November 2005 8:30:25 AM(UTC)
If they haven't been off for a long time (or were put back on when the paint was fresh), they will be held on by the paint or some surface rust.
A bit if BFI should fix it.
Cheers...Dave
#3 Posted : Sunday, 13 November 2005 8:37:03 AM(UTC)
looks like we both like reading everything twice
#4 Posted : Sunday, 13 November 2005 8:52:15 AM(UTC)
To protect your toes replace the upper bolts about halfway and loosen the bottom hinge first. It is a lot easier to control a heavy door if it still fixed at the top.
#5 Posted : Sunday, 13 November 2005 11:42:58 AM(UTC)
good thinking 99...
