#1 Posted : Tuesday, 15 November 2005 12:48:05 AM(UTC)
BARGAIN BRAND NEW UNDER DASH HEATER AND AIR CONDITIONING
WITH DEMISTER DUCTS AND EYEBALL DUCTS
TO SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE application
THE UNIT IS NEW ,THE CASING IS PLASTIC AND HAS BOTH HEATER EVAPORATOR CORES INSIDE UNIT
HEATER CORE IS ALUMINUM WITH 16 MM OUTLETS
OVERALL dimension are as below
HEATER AIR CONDITION Specs
CUBIC FEET METRE 359
Dimensions 400 MM X 325 MM X 125MM
COOL K/CAL 2650
HEAT K/CAL 4800
Volts 12
2242EV
The unit has a twin blower wheels with a three speed 12v motor
THIS UNIT IS COMPLETE WITH 2X DEMISTER DUCTS , 2X EYEBALL AND ONE UNDER DASH HEAT/COOL EVAPORATOR
$350.00 INC GST
PLEASE NOTE : YOU WILL NEED A/C COMPRESSOR , CONDENSER ,R/DRIER AND A/C HOSES
BARGAIN BRAND NEW
THE UNIT IS NEW
OVERALL dimension are as below $250.00 INC GST
COOL K/CAL 2650
HEAT K/CAL 4800
Volts 12
2242EV
THIS UNIT IS COMPLETE WITH UNDER DASH HEAT/COOL EVAPORATOR
BARGAIN BRAND NEW
UNDER DASH DEMISTER DUCT
THE UNIT IS NEW
UNDER DASH HEATER DEMISTER DUCT OUTLET SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE APPLICATIONS
ELIPTICAL DUCT INTAKE WILL SUIT 57mm (2 1/4'') FLEXIBLE TUBING.
You are bidding on one only, if you need two or more please enter the quantity you would like below.
$38.00 INC GSt
BARGAIN BRAND NEW
CHROME EYEBALL DUCT OUTLET
THE UNIT IS NEW
CHROME EYEBALL DUCT OUTLET SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE APPLICATIONS
CIRCLE DUCT INTAKE WILL SUIT 63mm (2 1/2'') FLEXIBLE TUBING.
$65.00 INC GST
BARGAIN BRAND NEW
UNDER DASH HEATER
THE UNIT IS NEW
THE CASING IS PLASTIC AND HAS BOTH HEATER CORE INSIDE UNIT
$200.00 INC GST
Dimensions 250 MM X 190 MM X 110 MM
Volts 12
The unit has a twin blower wheels with a two speed 12v motor
This unit side mounts
Any other questions please email me
I have photos of the unit
Can email to you
BARGAIN BRAND NEW
SANDEN SD7H15 AA SECTION PULLEY VERT
ORING EAR MOUNT COMPRESSOR
THE UNIT IS NEW
OVERALL dimension are as below $350.00 INC GST
COMPRESSOR Specs
NUMBER OF CYLINDER 7
DISPLACEMENT 155 CC
REFRIDGERANT R134A
CLUTCH VOLTAGES 12 VOLTS
OIL TYPE PAG SP20 TYPE B
Volts 12 VOLTS
ROTATION CW
PRICE LIST
Sp 9035 DUCTING TUBING /HOSE PER METRE 57MM $30.00 +gst
Lv 0223 LOUVRE BOX TYPE BLACK $55.00 +gst
Lv 0224 LOUVRE BALL TYPE BLACK $50.00 +gst
Lv 0478 LOUVRE BALL TYPE CHROME 57MM TUBE $55.00 +gst
Lv 0128 LOUVRE BALL TYPE CHROME 63MM TUBE $65.00 +gst
Sp 9034 DUCTING TUBING /HOSE PER METRE 63MM $30.00 +gst
Lv 1018 DEMISTER DUCT $38.00 +gst
CM 7863 SD7H15 AA SECTION V/ORING EAR MOUNT $350.00 +gst
HA 2701 DEMISTER HEATER COMPLETE $200.00
