#1 Posted : Thursday, 17 November 2005 12:11:30 AM(UTC)
Have a 1981 TF Cortina 4.1 x-flow with alloy head Stromberg carby. Is it possible bolt a 1988 Falcon XF inlet manifold and Weber carby straight on to the 81 TF block ?? Or are there problems ?? Also does the air cleaner clear the underside of the bonnet ? If you have done this modification successfully I would like to know all I need to thru this site or even better it would be great if you could ring
07 3867 2011 to leave your number on my voice mail and will ring you back to save you call costs. Thanking you for your response.
#2 Posted : Thursday, 17 November 2005 1:39:59 AM(UTC)
it all bolts straight on,i have it on my te cortina.i think the xe had a better carb (same but with less crap hanging off it) but either carb is good and a great increase in power and use less fuel
#3 Posted : Friday, 18 November 2005 11:41:00 PM(UTC)
I appreciate your prompt reply.
1. Does the XE air cleaner touch the underside of the TE bonnet ?
2. Does the TE accelerator cable linkage fit the Weber carby ? or is it to be modified ?
3. Can the Cortina fuel pump be used and does the configuration o
#4 Posted : Sunday, 20 November 2005 11:21:19 PM(UTC)
1,no it does not touch.2,yes it does fit and it does not need to be modified.3,you must use the cortina fuel pump,a falcon one dont fit because of the engine mounts (the cortina ones are the same but were made with an angle on the bottom of the pump to cl
#5 Posted : Monday, 21 November 2005 11:50:51 PM(UTC)
Thanking you for the info it will make the conversion just so much easier. Have noted the Cortina web site and will look forward to reading the forum. All the best Verne
#6 Posted : Wednesday, 23 November 2005 1:00:15 AM(UTC)
can i put a xe carby on a xf
#7 Posted : Wednesday, 23 November 2005 8:03:06 PM(UTC)
sure can but you will have to block off a few line which wont bother the car.why do you want to do this?if you can put a holley on an xf you can put an xe carb on one
#8 Posted : Wednesday, 23 April 2008 7:27:53 AM(UTC)
i have a te cortina 4.1L i just want to know i have tried everything to get my corty to get curb idle but it wont i have cleaned the carby, screwed around with timing, spark plugs leads everything but rippin the motor apart and that is 1 thing i dont want
Guest (5)
