#1 Posted : Thursday, 17 November 2005 8:17:01 AM(UTC)
Hi Guys,
Anybody out there running a gas research throttle body on a 5 Liter engine? I have a question regarding the differences in the bell crank from the original one to the one found on the Gas Research unit.
The holden one is progressive 40mm rad to 20mm rad, the Gas research one is 40mm rad constant. Because of this you need a longer stroke in the cable to allow for the GR bell crank.
Did you use the GR bell crank or something else?
TIA
Regards
Rob
92 RR VT5L for a heart
Bayswater Vic
