#1 Posted : Tuesday, 22 November 2005 5:25:43 PM(UTC)
Hi everyone, whats the procedure and parts for changing FB brakes to the larger EH drums , The FB is on historic and cannot have disc brakes. thanks
peterwmh Offline
#2 Posted : Wednesday, 23 November 2005 7:26:13 AM(UTC)
peterwmh
Look I haven't done the conversion, however they are both conventional kingpin front ends. I'd measure the stub axles and if they're the same, then all you'll need is the backing plate, all the brake shoe parts and slave cylinder and of course the drums.
#3 Posted : Thursday, 24 November 2005 5:21:21 PM(UTC)
thanks
#4 Posted : Friday, 25 November 2005 11:05:27 AM(UTC)
You might be able to sneak through with Hk/T/G drums all you need is the drums the and backing plates and shoes the hubs/bearings bolt straight on and you can fit the 14" wheels (not sure if the 13s will go over the larger drums?). The stub axles are the
#5 Posted : Friday, 25 November 2005 11:06:30 AM(UTC)
Oh you cannot fit the HK rims they have different offset and rub on the body.
#6 Posted : Saturday, 26 November 2005 4:56:17 PM(UTC)
Hi John, 14`s are not allowed with Historic reg 13`s only as per factory.
#7 Posted : Sunday, 27 November 2005 10:03:28 AM(UTC)
You might be able to fit 13s to the Hk etc drums, the problem with the disks is the caliper clearance and you don't have that problem with the drums.
