#1 Posted : Tuesday, 22 November 2005 8:07:44 PM(UTC)
Hi,
I want to drain the fuel tank on my ED Falcon, but I got under the car the other day and couldn't find a drain plug. Can someone tell me how to drain it. I need help urgently.
Thanks.
#2 Posted : Tuesday, 22 November 2005 11:36:45 PM(UTC)
the best way to do it would be to disconnect the fuel line in the engine bay & re route it to a large jerry can. Connect the fuel pump straight to 12v & it will pump the fuel into the jerry can for you
#3 Posted : Wednesday, 23 November 2005 3:18:18 AM(UTC)
Can I remove the fuel tank from the car? this way, i can clean the tank as well. how do I remove the fuel tank? is it simply undoing the mounts?
Thanks.
lonemonaro Offline
#4 Posted : Wednesday, 23 November 2005 4:50:00 AM(UTC)
lonemonaro
Hi,
Jim's idea is the best, as you will never be able to drain all of the petrol out of the tank. I removed my tank from my XC, and tried to completely drain it.
I was left with an estimated 1 litre of fuel sloshing around and it wasn't worth the fi
This page was generated in 0.097 seconds.
