mono Offline
#1 Posted : Wednesday, 17 March 2010 8:53:37 AM(UTC)
mono
i pulled a fuel tank out of a factory v8 hg ute today and was wondering is it the same as v8 coupe fuel tank,thanks mono.
#2 Posted : Wednesday, 17 March 2010 5:34:05 PM(UTC)
There are three fuel tanks in HG.
16 gallon banjo
16 gallon salisbury
25 gallon
Utes have the first two, and you would need it to be a factory 308 manual or 308 auto with high performance diff option to have number 2.
So what you more than likely have is number 1 which is th same as a 6 cylinder tank.
Warren
#3 Posted : Wednesday, 17 March 2010 5:36:07 PM(UTC)
Was thanked: 618 time(s) in 584 post(s)
If it was a 253 ute it will be the same as a HG 253 GTS coupe or a 253/308 auto Monaro coupe with banjo. It wont fit a body with a Salisbury diff, unless the ute was a 308 manual, or possibly a Salisbury optioned 308 auto.
80737k Offline
#4 Posted : Wednesday, 17 March 2010 9:55:34 PM(UTC)
80737k
marking.
Fossil fuels are YUMMY !
#5 Posted : Thursday, 18 March 2010 3:24:14 AM(UTC)
Hi Gents
Could someone just confirm how you can tell tank 1 from tank 2??
#6 Posted : Thursday, 18 March 2010 3:52:01 AM(UTC)
By the hump in the front edge, put there to clear a 12 bolt Salisbury but also fitted to all 10-bolt vehicles.
#7 Posted : Thursday, 18 March 2010 4:08:18 AM(UTC)
Thanks Byron
So is that a recess into the leading vertical face of the tank, or a raised section in the floor and therefore the top of the tank??
#8 Posted : Thursday, 18 March 2010 6:26:35 AM(UTC)
Raised section in the floor in front of the tank, and the tank is shaped to follow it.
#9 Posted : Thursday, 18 March 2010 7:39:01 AM(UTC)
Right
Thanks Byron
mono Offline
#10 Posted : Thursday, 18 March 2010 9:25:31 AM(UTC)
mono
Thanks for all the help.Turns out to be the one with the hump on the front edge.again thanks heaps.mono
#11 Posted : Thursday, 18 March 2010 5:16:51 PM(UTC)
Very rare HG ute then as it must have been a 308. Was it a 4spd or auto?
#12 Posted : Thursday, 18 March 2010 11:37:12 PM(UTC)
Would be advisable to cut teh hump out of the ute also. Also saginaw hump on left side of trans tunnel would be handy for someone.
Warren
80569K Offline
#13 Posted : Friday, 19 March 2010 2:50:42 AM(UTC)
80569K
Option 1. Put it all back together and put it on ebay and advertise it as a monaro donor (now donning helmet & flak jacket).
Option 2. Fix it up and have a very rare ute.
Option 2. would be my pick.
Reality is only an illusion which occurs due to a lack of alcohol.
mono Offline
#14 Posted : Friday, 19 March 2010 10:03:19 AM(UTC)
mono
I have asked for some help decodeing the ute id numbers in another question and i am now wondering weather it would be worth spending the dollars on.does any body have an opinion on what it could be worth restored,as i am a dual trade panelbeater spraypainter so a lot of the resto would be time.but it would be good to know that it would be a desirable vehicle when finished.(I KNOW I WOULD NEVER GET MY MONEY BACK FROM A FULL RESTO)thanks heaps,mono
Guest (5)
This page was generated in 0.230 seconds.
