RussVRute Offline
#1 Posted : Monday, 28 November 2005 3:40:23 AM(UTC)
RussVRute
G'day all,
I have bought an HZ front clip, bonnet and radiator support panel for the HX Tonner, which presently has an HQ front, will I need to get the guards as well or can I just keep the same guards and just change the bonnet and front end? Its not a big problem, because I can get HZ guards if I need to, but would like to know before hand so I can hopefully do the changeover in one hit. Any advice appreciated. Thanks. Russ.
mackv8 Offline
#2 Posted : Monday, 28 November 2005 3:45:15 AM(UTC)
mackv8
you will nead the hj hx hz guards and the inner guards.
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
#3 Posted : Monday, 28 November 2005 4:25:15 AM(UTC)
Russ
I suspect you actually have a HX front on the tonner, as the HQ style front is standard on all HJ-HZ tonners that aren't BO6 packs (ie ambulance packs). As per MackV8's reply, you'll need the whole front including guards and bonnet. The bonnet als
