ozjason Offline
#1 Posted : Monday, 28 November 2005 6:39:22 AM(UTC)
ozjason
So... now that I've finally got this alarm going in the Torana, I got to thinking... All the warnings that come with new cars regarding using a surge protector when jump starting them... does that apply to our "old girls" if we have electronic devices in them?
I've had no trouble jump starting me or others with the stereo wired up, but how about an alarm, or cruise control?
Or is it just the engine management modules that can be affected?
Has anyone had any trouble?
Jason.
#2 Posted : Monday, 28 November 2005 9:03:33 AM(UTC)
Surge Protection while jump starting cars with computers in their wiring is very desirable.
The other way to do it is to have both cars turned off, connect the jumper leads (positive first), then start the donor/jumper car, then start the jumpee/flat b
ozjason Offline
#3 Posted : Monday, 28 November 2005 5:38:27 PM(UTC)
ozjason
Ah, so it's not the starting that risks the computers, it's the connection and/or disconnection while there's an alternator pumping current out...
That's the same for all modern cars also?
Jason.
Dylan Offline
#4 Posted : Monday, 28 November 2005 5:39:28 PM(UTC)
Dylan
when i was doing a TAFE course once i had a pretty switched on mechanic tell me that the inline surge protectors on jumper leads arn't quick enough to stop a spike damaging an engine managment computer, i dont know if technology has improved since then, b
jabba Offline
#5 Posted : Monday, 28 November 2005 9:26:54 PM(UTC)
jabba
The other thing which can help is to turn on lights / fans / etc on the "good" car while connecting, to reduce the voltage difference between the good and bad batteries.
Once connected, switch off all extras, start "good" car, then you can start "bad
#6 Posted : Sunday, 4 December 2005 1:44:34 AM(UTC)
Hi Jason,
Yeah mate, it is the same for all cars. In reality, the way I described the process above is how you should do it always.
Cheers...Dave
