ExportHolden Offline
#1 Posted : Sunday, 4 April 2010 5:22:31 AM(UTC)
ExportHolden
My WB Statesman has had a noisy lifter since I bought it about 2 months ago, and Ive tried an engine flush and a couple of oil changes and have used lifter conditioner, but the engine still tapped away. I know it's not the end of the world on a tired 206,000km 308, but it's the one thing that makes my otherwise tidy De Ville seem like an old clunker. The exhaust system is quiet but you could hear the old WB coming because of its tapping lifter.
So I tried something I've never heard of before, and that was grinding the rocker post on the one rocker that I had discovered had play in it (I checked the bolt tension first, and torqued it up a little, but the rocker still had some movement in it - the others were as tight as a drum.)
So after grinding down the post (with several layers of cotton around the work area to catch to metal filings) I bolted it all up, no play at the rocker anymore, and to be honest I still thought it wouldn't work and that the lifter wasn't going to pump up, despite my effort to pre-load it. So I fired up the engine. It was tappping away initially, but after about 10 sec it started to quieten down.
Sure, there's a bit of valve train noise, but that annoying, loud 'tap-tap' has gone. So thanks, Dr Terry, it worked! I'm sure for most of you guys this is pretty basic but geez it's satisfying to work on a car and get such good results without having to pull the thing completely to bits. Love this WB, it's not only a cool car but I really enjoy working on it.
#2 Posted : Sunday, 4 April 2010 6:49:04 AM(UTC)
Was thanked: 618 time(s) in 584 post(s)
Why didnt you just file the rocker bridge down with it off the car? Saves stuffing a head!
#3 Posted : Sunday, 4 April 2010 5:18:12 PM(UTC)
ExportHolden
It needed about .25mm ground off, if that. I intended to grind it in stages and I didnt even have to have a second go at it before getting the desired effect. How will that stuff the head? Do you mean when it comes to rebuild time the head cant be used with that amount ground off?
I also wondered about grinding the rocker bridge but I didnt want to risk weakening it, although in hindsight the very little I needed to grind off probably wouldnt have.
#4 Posted : Sunday, 4 April 2010 6:08:12 PM(UTC)
.25mm wont hurt it. When we used to put reground cams in red 6s we had to grind the rocker bridges down to suit the new cam base circle, and they are the same bridges so even a few mm wont hurt them.
#5 Posted : Sunday, 4 April 2010 7:14:45 PM(UTC)
heads are cheap anyway,your is obviously still useable anyway,i was wondering why you wouldnt just replace the rocker and rod thou?,
or is it a slightly collapsed lifter?
grinding the post down will put slightly more tension on the valve spring,but its a brilliant fix..
P.S.,i"ll have to remmember that one.
Edited by user Sunday, 4 April 2010 7:20:06 PM(UTC)  | Reason: Not specified
Utility8 Offline
#6 Posted : Sunday, 4 April 2010 7:53:46 PM(UTC)
Utility8
Yep, was gunna ask the same question. Why grind the head & not the rocker bridge pair? Makes the head a throw away I would have thought. I recently did a full set on a 202. Had around 25-40 thou clearance at the valve, sounded terrible, rattled like a bastard. Bit of a chat with a few engine builders, then took each one off in turn & filed flat & square. From memory, decided to take a nominal figure of 30 thou off each to keep things uniform. Rocker ratio would bring the tolerance in at the valve. One hour later, start up was instant quiet.
I had the full set of six bridges to do. The head was a reco & all tolerances were out about the same dimension. If you had one rocker that was an issue, maybe you have a lifter failure or cam lobe gone. Shouldnt be too long before it raises its ugly head again.
Utility8
Edited by user Sunday, 4 April 2010 7:55:51 PM(UTC)  | Reason: Not specified
utility8
#7 Posted : Sunday, 4 April 2010 7:57:51 PM(UTC)
Have to agree, 206000km isnt a lot for that age car. Lots of slow running and I would bet the cam is losing a lobe for sure as a result. I bet the lifter noise comes back in no time.
#8 Posted : Sunday, 4 April 2010 8:02:51 PM(UTC)
It really will need a new cam, lifters and oil pump at some stage soon, but if its just a cruiser that will do 200kM a year it should be right for a while.
#9 Posted : Sunday, 4 April 2010 10:47:54 PM(UTC)
Fair enough I suppose.
#10 Posted : Monday, 5 April 2010 5:29:56 AM(UTC)
Dont worry - if/when the time comes for a reco job on the head, and you need to reverse it, you just shim up the rocker bridge to the original height.
Years ago (on P plates from memory) I filed all mine down when I got a reground cam. Then when I got a new cam, they were all too low.
Being young & short on cash at the time, I found 16 flat washers all the same, and used them as shims. That motor survived many thousands of km worth of youthful spiritied driving (read young & stupid!).
#11 Posted : Monday, 5 April 2010 6:25:41 AM(UTC)
ExportHolden
Theres more than one way to skin a cat, eh? Maybe I havent done the job the best way, but I got the result I wanted for the short term I hope it lasts. I drove the WB about 25km today and it was great to pull up at the lights and not hear the lifter tapping.
The WB isnt driven a whole lot and while itll do more than 200km a year it wont be much more than 2000km. I was hoping the engine would last at least a year or two before pulling it out and rebuilding it. And when I do I guess Ill have to shim one of the rocker posts...
#12 Posted : Monday, 5 April 2010 6:33:55 AM(UTC)
I hope i speak for all on this forum,we arent knocking it ,we are just
discussing stuff,personally i think its a brilliant fix.
#13 Posted : Monday, 5 April 2010 5:19:47 PM(UTC)
Your right, it is a good easy fix that suits the purpose.
#14 Posted : Wednesday, 7 April 2010 3:47:58 AM(UTC)
ExportHolden
The rocker bridge is what I shouldve ground down.. I made a mistake. Oh well, live and learn...
Today the WB blew its top radiator hose, I fixed that, then while checking ignition timing it started to rattle from another lifter on the left bacnk (previous was the right bank).
I pulled the rocker cover off and one of the rockers is really loose, much more than the other side was. The pushrod has marks around it too where it looks like it has been hitting the side of the (presumably collapsed) lifter.
Oh well, maybe its time for a new cam and lifters. I was hoping to save up and do a complete rebuild in a few years...
HQforme Offline
#15 Posted : Wednesday, 7 April 2010 3:58:02 AM(UTC)
HQforme
Youve discovered the joy of fixing a car yourself, brilliant! Youve also discovered how "easy" old cars can be, and yet, how tricky it is.
Ive had to at times grind down ricker bridges on 202s, use lash caps on valve stems (little spacers between rocker arm and valve) and i went through 3sets of lifter in my worked 202 trying to stop a solitary tap. It failed. Lobes are good, adjustable roller rockers, preload correct, etc etc, just a mystery lifter noise.
Anyhoo, sounds like yours, sadly, is dying. If you want to tackle it yourself then the old Holden donks are perfect for learning on, but beware, like this job, it CAN be more tricky than it seems.
Get a compression test done, good indicator of general health. You might get away with new cam and lifters.
Or else, throw $2500 at a mild rebuild with new cam, shaved heads and unleaded seats, then enjoy fresh, spritely motoring.
"Silly modern cars"
"Silly modern cars"
#16 Posted : Wednesday, 7 April 2010 6:37:46 AM(UTC)
"Get a compression test done".Words to live by HQforme,I dont know why more
people dont do that first,its the shocking truth.
