I thought this could help alot of people out there! http://taylormade.com.au...es/conversion_table.htmlJim in Adelaide...Hindsight is bad vision! Edited by user Tuesday, 6 April 2010 5:36:00 PM(UTC)
| Reason: Not specified |
Jim in Adelaide.. |
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Just added to bookmarks, will be very handy for my line of work!
Nicely done.
Its amazing how many handy little calculators are out there with a simple google and a few parameters. Units of all kinds, carby CFM, accurate compression ratio, speedo correction with change in tyre size, all valuable.
"Silly modern cars" |
Heres one of my favourites. Its a tyre section calculator. Input your original tyre sizes and the sizes of the wheel/tyres you wish to fit and it will give you all the dimensions to let you know how much clearance you will need as well as ride height and speedo accuracy. Its an Excel spreadsheet so download and save to use any time. http://www.superjamie.net/garage/tire.xls
