308hjute Offline
#1 Posted : Friday, 16 April 2010 5:48:50 AM(UTC)
308hjute
How the hell do I put my springs back in to the tonner? I have just replaced all bushes and balljoints and started to put it all back together this arvo. Do I need spring compressors of some description? If so, what type do I need?
Kev
AMunro327 Offline
#2 Posted : Friday, 16 April 2010 6:00:43 AM(UTC)
AMunro327
Havent done it in a HZ, but have to several other cars. My method is
Get a length of half inch threaded rod (or similar)thats long enough to go through the Shock absorber hole in the lower control arm, and through the top shock absorber hole. It will need a bend of about 20 or so degrees at about the lower pivot point. Screw a nut onto the thread at the top to hold it in place. This rod will prevent the spring from flying out at you if there is some sort of mishap.
Put a trolley jack under the outer end of the lower control arm, with the spring in place. Jack up slightly and make sure the spring is located correctly top & bottom. Jack up til you can install the upper & lower ball joint nuts. Dont lower the jack til you have both lower & upper ball joint nuts tight. Remove the rod.
#3 Posted : Friday, 16 April 2010 6:39:32 AM(UTC)
PITA for original springs, but aftermarket ones are a snack.
roy1126 Offline
#4 Posted : Friday, 16 April 2010 7:46:17 AM(UTC)
roy1126
Hi
I have used spring compressors but because of the confined space and not being able to get the compressed springs and compressors in, I have wired the springs compressed, removed the compressors and then just slid them in tightened the balljoints and then cut the wire.
It feels like your holding a bomb when youre handling the wired springs, and it makes a hell of a bang when you cut the wire, but it works.
All the best
Roy
gtrpu Offline
#5 Posted : Saturday, 17 April 2010 12:33:48 AM(UTC)
gtrpu
You could always jack the car up and put stands under it then use then put the spring in and use the jack to raise the lower control arm until you can get the nut onto the lower ball joint.
#6 Posted : Saturday, 17 April 2010 12:57:10 AM(UTC)
That is how you do it easily with aftermarket springs. Its not that easy with original springs as they are generally about 3" longer.
#7 Posted : Saturday, 17 April 2010 1:33:49 AM(UTC)
get mates to help (trust me)
308hjute Offline
#8 Posted : Saturday, 17 April 2010 2:53:02 AM(UTC)
308hjute
Originally posted by roy1126
Hi
All the best
Roy
Thanks Roy, the bit about holding a bomb made me laugh. Also makes me not want to try it.......
Kev
#9 Posted : Saturday, 17 April 2010 3:44:44 AM(UTC)
Kev
To avoid the hassle just buy a pair of aftermarket springs in any height. They go straight in as gtrpu describes.
adam PERTH Offline
#10 Posted : Saturday, 17 April 2010 5:01:06 AM(UTC)
adam PERTH
jack the chassis up at the front very high too
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
#11 Posted : Saturday, 17 April 2010 5:21:20 AM(UTC)
Listen to hk1837, aftermarket springs, no need for spring compressors or lethal bits of wire.
klompy Offline
#12 Posted : Saturday, 17 April 2010 7:03:58 PM(UTC)
klompy
Hi which aftermarket brands are better or are they all much the same quality wise.What have you used with good results,Thanks Mike.
#13 Posted : Sunday, 18 April 2010 5:53:24 AM(UTC)
save your money!!!
just muscle them in!, get a pry bar and force them in, use your foot to push the control arm down and lever them into postion then place jack the control arm up and jack it up, ive done it plenty of times
standard springs arnt easy to put back in, but spending money on new ones is crazy
308hjute Offline
#14 Posted : Sunday, 18 April 2010 6:26:01 AM(UTC)
308hjute
Got em in. Used a couple of bits of angle and bolts to compress them internally. Got them sitting where I needed them, then jacked the lower control arm up, undid the backyard compressors, and bolted the ball joints up. s*** of a job.
Kev
#15 Posted : Sunday, 18 April 2010 6:48:56 AM(UTC)
good work :-)
yep, defantly a sh1t of a job with standard springs
lowered springs are easy
Edited by user Sunday, 18 April 2010 6:49:53 AM(UTC)  | Reason: Not specified
#16 Posted : Sunday, 18 April 2010 7:53:44 AM(UTC)
I didnt mean get new aftermarkets. I meant find secondhand ones. They are everywhere. Just ask Greg how many cars have them.
308hjute Offline
#17 Posted : Sunday, 18 April 2010 10:23:59 AM(UTC)
308hjute
I did actually have a set of aftermarket springs in the garage for 4 or 5 years from a wagon I stripped. Got sick of moving them around and tripping over them so threw them out. Kicking myself now.
