#1 Posted : Tuesday, 20 April 2010 5:10:40 AM(UTC)
horse power increase per each change?
I have heard that fitting thermo fans and removing your other fan will
give you about 10 extra horse power.(I know it does but)
1.Is this true and accurate?
2.Does anyone else have small single modifications with HP increase ratings?(like electric fuel pumps ETC)
greenhj Offline
#2 Posted : Tuesday, 20 April 2010 5:25:30 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
in theory an electric water pump should be worth a few, after a certain point i dont think more water flow is needed and its robbing power for no benefit.
Regarding fans before someone mentions a viscous coupled fan not using much power to drive, once your doing 30mph you dont need any additional airflow and even the viscous coupling is "using" power albeit ridiculously inefficiently (nothing much is happening for the input)
Dunno about electric fuel pump though, a mech pump flows in proportion to rpm but an electric supplies way more fuel than is needed and bypasses the rest.
So the input horsepower per lb of fuel USED is probably higher with an electric.
Worse still for people who insist on electric pumps capable of filling a 44 gallon drum in 2 minutes on a 400hp engine lol.
Cold air is the cheapest power upgrade youll ever perform to your engine, even if you use a factory snorkel youll see a bunch of benefit by ducting cool air to the entry (id add another snorkel too)
The worst thing you can do is leave the aircleaner under the bonnet to suck ambient +50c air, so let it breathe externally and its worth a bunch of (really free) horsepower.
11.38@117
Edited by user Tuesday, 20 April 2010 5:29:40 AM(UTC)  | Reason: Not specified
#3 Posted : Tuesday, 20 April 2010 5:29:31 AM(UTC)
the biggest power (and economy) increase ive noticed is going from points to HEI dizzy
i changed my fan to a clutch fan and shroud, i havent noticed any power change at all with that
greenhj Offline
#4 Posted : Tuesday, 20 April 2010 5:34:09 AM(UTC)
greenhj
apart from cold air which really is worth a bunch, i suppose we are talking about mods that realistically add less than 5hp at a time (if the parts you replace were working properly to begin with)
anything mechanical thats replaced by electric still needs to produce the power, and alternators arent real efficient at turning mech energy into electrical so there are always losses trying to change the input energys state.
The savings are made by "choosing" when to operate the device, instead of it permanently coupled and running all the time (like a fan)
Ive never tested any of this stuff on a dyno, but if you make 5 mods that free up a few ponies each, thats a fair upgrade for cheap.
(someone find me some power without opening the engine or removing 20kg seats, and ill buy you a beer when the car runs a 10 lol)
11.38@117
Edited by user Tuesday, 20 April 2010 5:37:40 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, 20 April 2010 5:34:57 AM(UTC)
roller rockers?any hp figures for them?
just small increases would all add up.
I know about the big ones like turbo and supers
and nitrous,but in theory if you could do 5 small
changes to your engine(easy ones)you could gain
a fair bit.
So thats what Im trying to get ..lots of
small ideas that could help everyone and their
fuel bill...lol:-)
Edited by user Tuesday, 20 April 2010 5:39:51 AM(UTC)  | Reason: Not specified
#6 Posted : Tuesday, 20 April 2010 5:38:27 AM(UTC)
Was thanked: 618 time(s) in 584 post(s)
What about better oil?
#7 Posted : Tuesday, 20 April 2010 5:41:49 AM(UTC)
SLICK50...Byron apparently the ducks guts(expensive though!)
greenhj,thats exaclty what im asking,well put... 5 smallish changes.
Edited by user Tuesday, 20 April 2010 5:45:03 AM(UTC)  | Reason: Not specified
greenhj Offline
#8 Posted : Tuesday, 20 April 2010 5:46:01 AM(UTC)
greenhj
nah, never tested this kind of stuff, i just accept that at a certain power level/rpm i need to throw factory junk in the bin and buy better parts lol.
Reducing friction with the rollers is a good thing, but its possible they weigh more than a stamped factory bit of junk so valvetrain weight goes up.
help me out by explaining the application, roller rockers aint cheap and the money could be better spent elswhere up to a certain point.
If you want to get real spendy some low friction rings and a vac pump would be worth 20 or 30hp on a 450hp engine, maybe more depending on stroke.
For most normal people, Ill add a tick for a real good carb tune, i found bunches of power in my holley but i had to get "creative" in modifying metering blocks, because the "out of the box" tune was horrible.
Also, a dizzy recurve is good money spent.
another thing ive found, if you beleived everyone whose product was worth 5hp here and 10hp there, wed all be driving 1000hp 308s and while that would be nice, it aint ever gunna happen lol.
11.38@117
Edited by user Tuesday, 20 April 2010 5:46:36 AM(UTC)  | Reason: Not specified
#9 Posted : Tuesday, 20 April 2010 5:47:16 AM(UTC)
ive never used slick 50 but i know a guy who swears by it!
at $60 a bottle itd want to be good!!
has anyone here used it?
theres a slick 50 sticker in the engine bay of my car, so i assume the prevoius owner has used it in my motor
#10 Posted : Tuesday, 20 April 2010 5:50:01 AM(UTC)
roller rockers reduce the ressistance of the top of the engine therefore i think it revs up a little faster by not having the metal to metal kind of thing happening.old school explaining i know but you get the idea?
DAVE ,I wish I could afford the sticker!!!..:-)
Edited by user Tuesday, 20 April 2010 5:51:14 AM(UTC)  | Reason: Not specified
greenhj Offline
#11 Posted : Tuesday, 20 April 2010 5:53:36 AM(UTC)
greenhj
good sump is worth plenty, too much oil splashing around inside a holden engine and all its doing is draggin on the crank.
The deepest sump you can fit, with a good windage tray is worth good power.
Oils, ive never really bothered with, i need the oil to keep the engine alive, thats one place I dont really mess around with lighter grades or fancy synthetics.
cam timing is another place to tinker, the purists can probably explain the stocker 308s cam differences but from what i know the grinds didnt alter much but the phasing did and there is free power to be had by getting the valve motion closer to optimum (if youre a tightarse and dont want to fit a better cam)
11.38@117
Edited by user Tuesday, 20 April 2010 5:54:57 AM(UTC)  | Reason: Not specified
#12 Posted : Tuesday, 20 April 2010 5:56:12 AM(UTC)
haha, i was talked into getting some until i went into supercrap and seen the price, i think ill pretend i use it by pointing to my sticker, lol
Tex Scrotum rides again Offline
#13 Posted : Tuesday, 20 April 2010 5:57:02 AM(UTC)
Ive read a few oil comparos in car mags and there is some HP there to be had,going to synthetic and using Royal Purple seems to be best.Those guys doing Engine Masters in the states seem to be on the ball.
I changed from castrol GP50 to Mobil 1 and I did notice a difference in the idle but have since gone back to diesal oil for fear of wiping out cam lobes.
Ive also heard good things about Slick 50.
In the end anything that removes friction has to improve HP.
greenhj Offline
#14 Posted : Tuesday, 20 April 2010 6:02:09 AM(UTC)
greenhj
What works in a pro stock engine, or jon kaases EM entry, isnt necessary worth a pinch of s*** to a dirty old holden motor.
especially if it has to live more than 5 minutes.
Even comparing lsx results (where the dyno is king, and people pay stupid dollars for gains) isnt really applicable especially with oils, as a holden flat tappet wont like synthetic oils for very long and sloppy old holden clearances wont be good with such a thin oil.
On an engine built to suit, perhaps but i wouldnt be dumping 150 dollars of synthetic into granpas ex taxi just yet lol.
As far as the topic goes,I want to burn more fuel, in as short a period as possible, and get as many lb/ft from each Btu as possible.
fuel economy is for priuses and grey nomads lol.
11.38@117
Edited by user Tuesday, 20 April 2010 6:08:27 AM(UTC)  | Reason: Not specified
#15 Posted : Tuesday, 20 April 2010 6:09:01 AM(UTC)
greenhj,very true ,this thread can be used for both really,i dont think
ill be havin a beer with you ,because from 11.38 to 10.9 is gonna haunt
ya,because the faster you go the harder it is to make up those split seconds.
For Other readers...16 seconds to 15 seconds fairly easy to get
14 to 13 a little harder
11 to 10 expensive and error full
10 to 9 well ,you get the idea...lol
but some good stuff coming out already ...thanxz everyone!!
ANOTHER KILLER THREAD BY YOU GUYS...P.S.BYRONS SANDMAN THREAD
IS STILL THE KING AND SAFE...LOL
Edited by user Tuesday, 20 April 2010 6:12:47 AM(UTC)  | Reason: Not specified
greenhj Offline
#16 Posted : Tuesday, 20 April 2010 6:13:59 AM(UTC)
greenhj
haha so true, except ive made some "free" changes since then (sealed carb to scoop, more carb tweaks etc), fitted new tyres (old tyres were rooted last time out) and have waited for the weather to turn a little nicer.
If it doesnt go .2xs maybe teens now ill cry lol.
Probably up the ante a little over winter, my engine is really just a b1tch motor so theres plenty to gain if i open it up.
11.38@117
#17 Posted : Tuesday, 20 April 2010 6:15:06 AM(UTC)
Diesel oil in a petrol engine? It has a detergent in it. I would be careful using that. Oil is cheap, engines are not.
Anything electrical has to save HP. The alternator has to run on and off regardless so the power it robs the engine to run cant be saved anyway.
The only way to really know is to try changing some things and put it on the dyno.
One thing I do know is that my Honda crf450x (I know its a bike but they are a very high performance motor) had titanium coated valves and a piston the same thickness as milo tin lid. It went like stink until the titanium coating went off the valves after 3000ks of racing. I replaced them with stainless valves and put new rings in and it lost a few revs out of the top end but it still goes hard. So the power gains were not worth a pinch of s*** as I sat on the side of the track. They also recommend replacing the piston and rings after 15 hours of use!
I know this has no relevance to cheap horsepower gains but just thought it was interesting.
greenhj Offline
#18 Posted : Tuesday, 20 April 2010 6:15:45 AM(UTC)
greenhj
this is why this thread appeals to me, its easy to throw dollars at something to find power, but getting the most of what you have is the hard part, and im hoping for this thread to reveal a revelation I havent already tried
11.38@117
#19 Posted : Tuesday, 20 April 2010 6:22:29 AM(UTC)
Ive heard and done this :locked up the passenger side engine mount ,it doesnt make any more hp,but it delivers what youve got better in the time of need.(also saves you money replacing it,learned that at the 13 second mark...lol
greenhj Offline
#20 Posted : Tuesday, 20 April 2010 6:32:36 AM(UTC)
greenhj
diesel oil is primarily used because of its higher zinc content, removed from petrol engines because the cats dont like it.
A lot of diesel oils have reduced the zinc content so its almost of no benefit any more, needs to be a specific oil probably labelled "off road use only" or "for old s***boxes" to satisfy the epa and keep our engines alive.
Not really relevant to a tired old stocker i suppose, but put some spring on a decent flat tappet and its crucial.
I think penrite do an added zinc oil, and im pretty sure harley davidsons use a blend that still has plenty of zinc in it.
Not really, on an old car with electric fans fitted you can see the power being robbed every time the fans start up and teh idle drops because the demand for electricity has increased over "normal".
you dont see it on late model stuff because they cheat and open an air bypass to bring the rpm back up so you dont notice but it sure as hell is using more power than before
this i agree with, but such small gains are barely measurable while discounting all other affecting incidents. A chassis dyno sure as hell isnt close to accurate enough, maybe an OEM engine dyno with a million dollars in sensors and software and a lab full of geeks to interpret the data.
I like to see chunks of 10hp before i pay any attention to it.
11.38@117
Edited by user Tuesday, 20 April 2010 6:36:27 AM(UTC)  | Reason: Not specified
Guest (17)
