GDay All I have just pulled the valve gear off a Black head that has been in the shed for a bit. It has shims (washers) of varying thickness under each pair. Why are these there? And will I need to use them if I put it (the head) on a Blue motor. I have some ideas why they are there but would like to hear from someone who knows for sure. I have the EFI system to sell as well. |
Wanted FJ Panel van |
Probably due to a reground cam, longer pushrods or other similar factors. Possibly the rocker bridges were ground down in the past for such reasons and a new standard base circle cam has been put in?
most likely had the head shaved resulting in to much preload on lifters if shims arent used.
MONARO!!WHERE!!NICE |
i have had to do this before to make sure the valves close fully after taking alot off the head.
WANTED: -2 14 x 9.25 CSA style Centrelines. -2 x 15 x 8 Dragway centrelines |
