#1 Posted : Wednesday, 7 December 2005 8:27:06 PM(UTC)
Ok guys, I have done some searching around the engine and found the following part Nos, Can anybody identify them and tell me if they are a match for a 186 fit or have I got the wrong parts fitted..
HEAD = 7438296 - (holden D 1 8 4 H)
BLOCK = 186P399005
MANIFOLD = 7434446-P (114)
WW CARBY = 23 3078 0 22 (with 55" jets)
Still fault finding, and this might rule things out. cheers guys Jimbob
#2 Posted : Thursday, 8 December 2005 1:42:39 AM(UTC)
I suspect the carb is HJ'ish 253. If someone can confirm the model and post it here:
http://fastlane.com.au/f.../topic.asp?TOPIC_ID=4382
#3 Posted : Thursday, 8 December 2005 1:42:39 AM(UTC)
I suspect the carb is HJish 253. If someone can confirm the model and post it here:
#4 Posted : Thursday, 8 December 2005 2:02:11 AM(UTC)
Hi jimbob.
The head is off a 161. The inlet manifold is HK/HT/HG 186S. The block is stock 186 late HT or early HG & the carby is 253 Auto HQ Aug '73 to Sept '74.
Dr Terry.
#5 Posted : Thursday, 8 December 2005 2:02:11 AM(UTC)
Hi jimbob.
The head is off a 161. The inlet manifold is HK/HT/HG 186S. The block is stock 186 late HT or early HG & the carby is 253 Auto HQ Aug 73 to Sept 74.
Dr Terry.
jimbobhtute Offline
#6 Posted : Thursday, 8 December 2005 2:02:14 AM(UTC)
jimbobhtute
Cheers Tom, I found the carby info. The 23-3078 WW is off a 253 V8 HQ from 73 to 74. jimbobhtute
1970 Green HT UTE...
#7 Posted : Thursday, 8 December 2005 2:07:22 AM(UTC)
Hi again
The 23-3078 WW carby is off a 253 V8 man Aug '73 to Sept '74 the 23-3077 is the auto, my mistake, sorry.
#8 Posted : Thursday, 8 December 2005 2:07:22 AM(UTC)
Hi again
The 23-3078 WW carby is off a 253 V8 man Aug 73 to Sept 74 the 23-3077 is the auto, my mistake, sorry.
jimbobhtute Offline
#9 Posted : Thursday, 8 December 2005 2:20:36 AM(UTC)
jimbobhtute
Thanks Dr Terry, Can you put a 161 head onto a standard 186 donk??? And if so what effect does this have on performance or other required mods to get smoother running?? Hmmm interesting.. jimbobhtute
#10 Posted : Thursday, 8 December 2005 5:21:59 AM(UTC)
i think you can it will just give you much higher compression.
zac
Just put a V8 in it!!!
#11 Posted : Thursday, 8 December 2005 5:32:07 AM(UTC)
A 161 Head on a 186 will give you about 11:1 compression which SHOULD run OK on 98 Octane PULP but will struggle with 96 and don't even THINK about 91...Some of it is explained here: http://www.oldholden.com.../Maths#Compression_Ratio
A
#12 Posted : Thursday, 8 December 2005 5:32:07 AM(UTC)
A 161 Head on a 186 will give you about 11:1 compression which SHOULD run OK on 98 Octane PULP but will struggle with 96 and dont even THINK about 91...Some of it is explained here: http://www.oldholden.com.../Maths#Compression_Ratio
Ar
#13 Posted : Thursday, 8 December 2005 8:13:25 AM(UTC)
my 186 stromberg has 58 jet and runs sweet...
Edited by user Thursday, 8 December 2005 8:27:03 AM(UTC)  | Reason: Not specified
#14 Posted : Thursday, 8 December 2005 6:56:41 PM(UTC)
Hi Guys.
Qute is pretty right about the suitability of todays fuels in an engine with such a relatively high compression ratio. This is why tuning is so important.
With the jetting of carbies the size of the main jet is only half the story, the size
jimbobhtute Offline
#15 Posted : Thursday, 8 December 2005 10:49:05 PM(UTC)
jimbobhtute
Well, the things you find out about your engine. Thanks guys. Now with the 11:1 compression ratio, do I have to change the valves and valve springs from the standard 186 type to a more suitable type to handle the load. When I last pulled the head off in
jabba Offline
#16 Posted : Thursday, 8 December 2005 11:39:20 PM(UTC)
jabba
The big thing with power valve is the manifold vacuum at idle and under acceleration.
I used to get shocking economy with lumpy cam, and when put vacuum gauge in, found that I was well into the powewr valves opening range at idle. So basically as soon
Edited by user Thursday, 8 December 2005 11:42:45 PM(UTC)  | Reason: Not specified
jimbobhtute Offline
#17 Posted : Thursday, 8 December 2005 11:54:06 PM(UTC)
jimbobhtute
Thanks jabba
What procedure do I use for checking Manifold pressure?? I have Timing set to around 8'-10' BTDC at the moment with no knocking. Replaced the balancer month ago because it had failed and shifted, so I assume it is correct now. Any
jimbobhtute Offline
#18 Posted : Thursday, 8 December 2005 11:54:06 PM(UTC)
jimbobhtute
Thanks jabba
What procedure do I use for checking Manifold pressure?? I have Timing set to around 8-10 BTDC at the moment with no knocking. Replaced the balancer month ago because it had failed and shifted, so I assume it is correct now. Anybo
jabba Offline
#19 Posted : Friday, 9 December 2005 4:59:25 PM(UTC)
jabba
An ordinary repco (or autometer or brand of choice) vaccum gauge, tapped into manifold (or base of carby vacuum port). Dont use the distributor advance vacuum port for a reading, because it works kind of backwards.
Most vacuum gauges have both inches
jabba Offline
#20 Posted : Friday, 9 December 2005 4:59:25 PM(UTC)
jabba
An ordinary repco (or autometer or brand of choice) vaccum gauge, tapped into manifold (or base of carby vacuum port). Don't use the distributor advance vacuum port for a reading, because it works kind of backwards.
This page was generated in 0.093 seconds.
