#1 Posted : Sunday, 11 December 2005 3:18:05 AM(UTC)
327 chev and turbo 400 with B & M shifter, comes with all engine mounts, wiring harness, radiator etc, everything you need to fit into HQ-WB. Chev runs but Heads needs attention, Burnt out valve or crook guides, Has bow-tie finned alloy covers, leccy ignition, extractors, holley etc etc as seen in pic....
$800.00 for the lot post here or call 0427 507 096.
view piccy here:
http://oldholden.com/?q=node/22603
blwnhj Offline
#2 Posted : Sunday, 11 December 2005 9:10:20 PM(UTC)
blwnhj
you may have said this somewhere and ive totally missed it & if so im sorry, but where about are you located?
BLWNHJ
BLWNHJ
#3 Posted : Sunday, 11 December 2005 11:05:58 PM(UTC)
what type of crank does it have and does it have the standard bore.
Just put a V8 in it!!!
#4 Posted : Monday, 12 December 2005 3:03:16 AM(UTC)
located in lismore n.s.w 2480
have no idea about bore/and or crank the motor is still sitting in my gts munro, is running and as is when i bought it....the reason for sale is i have a bombed 308 to go straight into the GTS when it is finished.....
blwnhj Offline
#5 Posted : Monday, 12 December 2005 9:51:28 PM(UTC)
blwnhj
sorry to waste your time, im in vic.
BLWNHJ
BLWNHJ
