#1 Posted : Monday, 12 December 2005 8:09:58 AM(UTC)
gday i have a problem i just changed my trimatic with a second hand one my problem is that it has reverse but it feels like its slipping and u have to rev it to about 2500RPM till it engages. Also when shifter is used to select first it slips till reved to about 1500RPM then engages but feels like it is still slipping .but when in drive it is fine unless its really hot then it might just shudder when taking off. does any one have a solution could it be the vacume modulator i have heared that this controls fluid pressure. any help would be great!!
cheers scott
#2 Posted : Monday, 12 December 2005 10:04:20 AM(UTC)
First thing to do Scott is to check your tranny fluid.
Take the car for a 20 minute drive to get the box to operating temp. Stop on flat ground, leave the motor idling in Park and check the fluid level. It should be at the Hot Full mark.
If it isnt,
#3 Posted : Monday, 12 December 2005 10:04:20 AM(UTC)
If it isn't
#4 Posted : Tuesday, 13 December 2005 3:18:54 AM(UTC)
gday
yer i have checked the trany fluid it is on full when hot mark after a lap around the block. any other ideas would be great. thanx for your help
cheers scott
#5 Posted : Monday, 19 December 2005 9:13:31 AM(UTC)
Hey there mate it sounds to me that your trimatic has worn reverse clutches and a worn pump very common in these. the reverse clutches are at the front of the trimatic behind the pump. Remove the pan check the filter for clutch material. Once the pan is o
#6 Posted : Monday, 19 December 2005 9:14:27 PM(UTC)
The answer to the question is not to install a second hand gearbox without having it either overhauled first or checked out buy the gearbox guys.
EAP
#7 Posted : Friday, 28 September 2007 2:03:05 AM(UTC)
i had a expert check over a trimatic he said it was in top shape kept it for a spare when i did get to use it it had no forward drive it all cost money so much for experts cheers
Guest (5)
