#1 Posted : Tuesday, 13 December 2005 6:44:10 AM(UTC)
400CI chev for sale 40 thou over 10/10 grind on the crank p/j gear drive, JP hi volume oil pump fitted as well as some chrome after market parts pistons are TRW forged 11/1 flat tops and crank and rods are standard fittment comes with standard starter flex plate and single point distributer.NOTE THE 400 HAS NO HEADS OR INDUCTION AND IS SOLD AS A SHORT BLOCK ASSEMBLEY!!!$500ono
Polished 4-point bolt in alloy roll cage to suit HQ-HZ sedans comes with all fitting hardware and is NSW certified legal bond brand!!!100 ono
1tun Offline
#2 Posted : Wednesday, 14 December 2005 6:29:42 AM(UTC)
1tun
Which part of N.S.W are you from?
#3 Posted : Wednesday, 14 December 2005 7:05:22 AM(UTC)
All parts are in WAGGA WAGGA N.S.W PH 0269213221 for more info thanks!!!
#4 Posted : Wednesday, 14 December 2005 7:29:53 AM(UTC)
Could you tell me does the motor require reconditioning or was it a good runner before you pull the top end off?
#5 Posted : Wednesday, 14 December 2005 10:07:28 PM(UTC)
Bores are in very good condition and would only require a hone to be used again and yes the engine was running when removed around 7-months ago it would require rings bearings cam/lifters and gasket kit to be in a1 condition.The reason for sale is the rec
This page was generated in 0.153 seconds.
