#1 Posted : Tuesday, 13 December 2005 5:48:34 PM(UTC)
Can anybody give some advice on the 2.8 blue motor, are they better than the 202 red , would they produce the same power !! , i am still making up my mind which motor to rebuild .
#2 Posted : Tuesday, 13 December 2005 7:31:09 PM(UTC)
Hi bob.
The 2.8 Blue is better in some ways, better ignition system, better head flow & manifolds. But it's only a 173, & without spending a lot of time, money & effort, it's not going to out-power a 202.
#3 Posted : Tuesday, 13 December 2005 7:35:27 PM(UTC)
No. A 202 red will kill the blue 173 for power and torque. Rebuild the red, using the rods out of the blue 173. You could use the high comp blue head too, but only if you use low comp 202 pistons. There are a few holes to drill in the block deck for this
#4 Posted : Wednesday, 14 December 2005 3:47:41 PM(UTC)
#5 Posted : Wednesday, 14 December 2005 6:10:52 PM(UTC)
Hi bob.
The Blue rods (also called Starfire rods) are much stronger, similar to XU1 rods. The Blue is better than the Red in the crank, rods, head & manifolds, why bother with the Red.
You say your Red is 'Low' compression, what is its prefix.
Dr
#6 Posted : Wednesday, 14 December 2005 10:37:00 PM(UTC)
Just to clarify, Dr Terry is asking for your Engine Number Prefix.
Cheers...Dave
